Underride traction bar mountint nut size?
Started by cboss70, December 07, 2023, 11:37:35 AM
cboss70
Ok I know this is a stretch but would anyone happen to know what thread and nut size is used to hold the under-ride traction bar onto the stud mounted to the frame rail near the front part of the leaf spring? My bars were off the car and I don't believe I have the frame rail mounting stud nuts so I wanted to buy generic replacements until I can see what originals look like and maybe go down that path.
jk66gt350
The diameter of my underride mount nuts is 15/16 ths.  Not sure of the thread.  I believe mine are original, but as third owner, I cannot be certain.
bobtail
believe the 15/16 size is correct, they are half nuts with something like triangles stamped into the nuts to make them lock nuts, I think they are fine threads, don't think you will be able to duplicate, probably will have to find some originals
Can't remember if I've posted this picture before on this site so here are some pictures of examples
S7MS427
Traction Master should be able to answer your question (http://www.tractionmaster.com/). (818) 565-1121.
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
Brant
I bit late here, but they should be the same as the rear bolt size, which is 5/8-18. Rear bolt is 2 3/4 inches long also. I would have to look at a car to see if the length on the front bolt is the same.
-Brant
Quote from: Brant on December 13, 2023, 04:50:23 PM
The front bolt that is welded to the bracket and also holds the spacer washers is much longer at 3 1/2.
cboss70
Thank you all- I used the pictures and shockingly was able to locate the original nuts!
