Going to install one of these on my car
Started by deathsled, December 11, 2023, 11:56:33 AM
deathsled
With all the talk of fires and disappearing vehicles I was recommended by a friend to put one of these on my car.  He is a just recently retired airline pilot having flown big birds so I trust his judgment having survived 30,000 hours of time up in the skies.  I will let y'all know how the install goes.
https://www.napaonline.com/en/p/NW_785116?cid=paidsearch_shopping_dcoe_google&campaign=GSC-Fasteners-Hardware&campaign_id=10947735022&adgroup_id=107081865346&adtype=pla&gclid=CjwKCAiAg9urBhB_EiwAgw88mfO9yp-N-ez5wLRLEraYzopeMAwWGBdZaJPyRyDmL3i3x1NuzNHBTxoCPgsQAvD_BwE&gclsrc=aw.ds&gad_source=1
Engine revving to disturb
JohnSlack
I know a couple of people who have installed those. Good idea.
John
A lot of people I know use those but I haven't made the jump yet. Let us know.
deathsled
Quote from: deathsled on December 11, 2023, 01:44:23 PM
Here it is. I am going in.
most excellent preferance, make sure it is adequately date coded for your choice vehicle
Marcus Aurelius
Our pronouns are We Won
"Usque Ad finem"
A-Snake
Quote from: A-Snake on December 11, 2023, 02:12:37 PM
Quote from: deathsled on December 11, 2023, 11:56:33 AM
I would recommend the knife-blade style instead. The screw type can have a corrosion issue and may not make good contact.    https://www.amazon.com/Battery-Disconnect-Isolator-Negative-Vertical/dp/B07YTWJQF2/ref=sr_1_1_sspa?crid=34LGZDUDR06RO&keywords=battery+cutoff&qid=1702321955&sprefix=battery+cutoff%2Caps%2C136&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
I wonder if they sell a RH/LH variety of that?
Those have been available since at least the early 80's. They originally were advertised as a theft deterrent. You unscrewed the green knob and put it in your pocket so no one could start your car. Of course it can be easily bypassed . Later consciences supported it being used for log term storage where a slight draw of current from the car would keep the battery from being drained.  A added benefit is that during storage and with the disconnect used there is no chance of a electrical fire from a faulty circuit that is normally powered by the battery.  Yes as has been stated corrosion can build up and common sense maintenance is a given . The basic one pictured has drawbacks but  can be  easily cleaned and less obnoxious looking compared to the knife blade lever type . But that is just my opinion.
KR Convertible
It won't prevent a fire, just delay it until you are driving your car!
Any car thief that can't get past that isn't going to have a very successful career.
greekz
I have been disconnecting the negative cable in using a rubber cap over the post for over 30 years.  No fires, no drained battery, no ugly add on.
SFM 6S1134  '67 GT-350 #2339
Quote from: greekz on December 11, 2023, 03:27:43 PM
I've been doing the same. Current repop Autolite 24F battery has been in the car since 2009 and still going strong.
Ditto
Lincoln tech
Should get 2 for added protection , and don't forget that oil filter magnet too   ::)  :o  :-\  LOL
