Going to install one of these on my car
Started by deathsled, December 11, 2023, 11:56:33 AM
Quote from: greekz on December 11, 2023, 03:27:43 PM
I have been disconnecting the negative cable in using a rubber cap over the post for over 30 years.  No fires, no drained battery, no ugly add on.
+3
Side-Oilers
I've always disconnected the positive terminal.  That way I know 100% there's no chance of electricity in the system, via a possible short.
What's the benefit of removing the negative terminal instead of the positive?
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
I stuck this one in the Model A. https://www.summitracing.com/parts/sum-g1442?seid=srese1&gclid=CjwKCAiAg9urBhB_EiwAgw88meQQlE_DZKu-pPJ3d1ZwhIHeT1EjlRZGIsvDkJy1CB0cEiDd0H8OthoCeokQAvD_BwE
It's hidden under the edge of the floor mat. Don't use a disconnect in a car that has a brain (OBD I (?) & II). it will have to relearn every time you reconnect.
greekz
The negative cable provides the grounding for the entire car via the engine block to the firewall.  Without a ground, nothing in the electrical system functions.  Disconnecting the positive is another way to isolate the battery, but the car is has a ground.  I just prefer removing the ground.
SFM 6S1134  '67 GT-350 #2339
Side-Oilers
Greekz, thanks for your reply.
Agreed, in a properly operating electrical system, disconnecting the positive or negative produces the same absolute no-current-possible results.
But, could there be an occurrence where there's a slight short somewhere in the system that could manifest into something bad if the positive is left connected?  I'd think that might be possibility.
That's why I choose to remove the positive.
I guess I could remove both cables, then been able to sleep completely worry-free.    ;D
Current:
Previous:
1957 T-Bird E-model
Lincoln tech
Quote from: Side-Oilers on December 11, 2023, 05:31:10 PM
Or install 2 of those  ;)
427heaven
X2 VAN .....Electricians and MEK A NICKS prefer to remove the power source not just remove a circuit, myself included!
greekz
I have never felt any anxiety by removing only the negative cable.  I suppose totally removing the battery from the circuit could be one more step to a peaceful nights sleep.  We all have to do what feels comfortable.
Don Johnston
I have been using the NAPA disconnect for years without a problem.  Definingly prevents any battery bleed.  Didi not use it on the 65 Mustang GT due to annoyance of having to reset the the clock each time.  I used a trickle charger instead which was disconnected when I was not going to be at home in case of fire.
Quote from: 98SVT - was 06GT on December 11, 2023, 05:11:04 PM
Sure you mounted your safely but it reminded me of a similar one mount on a 67 Shelby a few years back I found during an inspection. Someone didn't think it through IMHO. Might have been very exciting when the driver went to engage the parking brake and the cable was pulled against the post or cable end(s)
deathsled
Battery kill switch is installed.  Video is in the link.
https://youtu.be/hRIReH9TmQQ
The benefit of said switch works where your car is parked long enough for a thief to steal your car but not long enough for the thief to diagnose and remedy the problem.
Engine revving to disturb
Quote from: deathsled on December 11, 2023, 06:37:35 PM
counselor we are so impressed with your videos,  the tone, clarity and the eloqounce of your speech made for us the common folks easy to comprehend and follow.
your proper usage of P. P. E.s gloves, glasses was on point to not only illustrate the proper installation,  but a proper safe installation.
we give you two thumbs up !
if you ever leave the legal field, you could possible transcend as the  "Mechanical Ghuru"
best of luck !
Marcus Aurelius
"Home of the "Amazing Hertz 3 + 1 Musketeers"
I am certainly not a Shelby Expert
deathsled
You're hilarious, Tony.  I am barely above putting a nut and bolt together.  Any mechanical knowledge I have, which is entirely scant, is all derivative from all those around me and those who existed before me.  I have invented nothing, built nothing, welded nothing.
Quote from: deathsled on December 11, 2023, 07:24:53 PM
your modesty and humility knows no bounds.....
Marcus Aurelius
427heaven
SLED ..... Thats why you are a Lawyer.  It was fun to watch, but you over came all obstacles on your quest to install that damned new cut out switch. Congratulations! ;)
