Non-OEM Upgrades. What Have You Changed?
Started by Dalton, July 27, 2018, 12:05:16 PM
Dalton
We used to have a thread like this on the old forum and I always thought it was nice to see what changes or upgrades some of you have made to your car.
Mine is a '67 GT350. I've added an exhaust with Flowmaster mufflers, new Koni's as of last week, an aluminum radiator (until I restore my original), Pertronix Ignitor and a Flamethrower coil. Not too much. Everything else is original or correct.
What non-original upgrades have you made to your car?
Petronix
Hardened Valve Seat, Roller Rockers, a Tinted Windshield and Radial Tires, all the rest is stock, single master cylinder, points, etc/
1966 GT350H 289 HIPO Service Replacement Long Block installed in 1972, still searching for original block
It would be nice to know/include for those reading what year and model as some up grades may not seem as upgrades unless you take the year or even model into account. A avatar my not apply to people who have multiple cars.
 428
kjspeed
The only change that I've made personally was to add a halotron fire extinguisher. The list of changes the previous owner, John Barnes made is quite extensive:
1968 GT350 #2148
Boss 351 engine, 11.3:1 CR, Lunati cam, roller tip rockers, Weber 48IDA induction system with Shelby lettered intake, Cobra T oil pan, MSD distributor/MSD-6AL/Accel Super coil
Richmond Super Street 5-speed with 1:1 5th gear, Hurst Super Shifter
3.50 4-pinion 9 inch rear end with Moser 31-spline axles
Wilwood brakes front and rear, all suspension bolts are safety wired
Koni shocks all around
Lowering blocks/traction bars/anti-sway bar in rear
Ceramic coated headers, MagnaFlows, 3 inch dual exhaust with removable center section (I can unbolt from the header collectors to the rear axle and install straight pipes dumping out in front of the rear wheels for track use)
Inside it's got a Ford AM/8-track player, 200 MPH speedo, Cobra steering column mounted tach and 69 Mach1 hi-back seats (I also have the original seats), driver's side 3 point racing belts and some guy named Shelby scribbled his name on the dash with a sharpie.  :o
Outside it's painted Jade Green Metallic with a Boss 302 front spoiler and American Racing polished aluminum 200S rims with Goodyear F60/L50 bias tires (for show). For the street I have unpolished AR 200S one-piece aluminum rims with Cooper Cobra 235-60R15 radials. Much better riding than the bias tires.
Most of these modifications were done back in the early 80's
1968 Shelby GT350
1968 Mustang GT S-code
2009 Mustang Bullitt
557
67 gt500,lots of stuff(mostly by previous owners)Ditched the smog,single 4 barrel and manifold(have originals)hurst shifter(have original)headers,turbo muffs,dual exhaust.am,fm cassette(have original am radio but they cut side panels in back for 6x9s ugh)14x6 turbo mags and radials(have 1 rusty mag star with a bald speedway 350 on it)probably due to sagging springs..had air shocks which I ditched...    ..Hey it's far from concourse ,and kind of a mess,but it drives well and is all mine and was only 6k when I bought it plus I love the damn thing!!! Trent.    Oh yeah it was also originally Wimbledon white but the previous owner painted it black/gold with lemans stripes which it still is...
Corey Bowcutt
'68 GT350, Stainless steel headers (have original cast iron) and stainless true dual exhaust, no smog and added Monte Carlo bar.  The rest is original or at least period correct :).
#8
  Its all back to original now, but, back in the day my 67 GT 350 got: Side pipes, Konis, an Accel distributor, 750 CFM carb, shaved heads with a three angle valve job, headers, Hurst completion plus shifter.  It ran a best of 14:56 with open headers at U.S.30 - out side of Hobart IN.
  Late addition: Monte Carlo bar.  Even that came in a "Shelby Racing Co" box.  That is still on the car.
cbrown
Oh snap!    I need to figures how to upload pics
Real67gt350.     Tremec 600.  Roush 347 vintage air upgrades complete total control suspension front and rear.  Baddd asss   He's Gona drive it!
Instagram shows part of it but have not updated for few days. Follow it.  We have deadline just like those tv guys.  Lol
Chrisbrownclassics
papa scoops
66 350 dealer lemans cam, oo and me, headers and pipes tires/ wheels tork thrust.(orig 10 spokes on a old trailer since 67, no one like them)  68 350 wheels tires (magstars put on at dealer, have origs ) phred
Sixx7shelby
#11
67 GT350
Boss 302 crank, 11:1, ported heads, crane cam,hooker headers, paxton with 650 dp, msd pickup
Custom exhaust 2.5 all the way, no mufflers, modified 2.5 Shelby tips
Hurts shifter, Carroll's signature
Gold Trac differential
Bigger front sway bar, rear bar
Stiffer springs,
Koni shocks
Global west control arms, lowered uppers
Poly urethane bushings
Under rider traction bars
Braided steel front brake lines
67 GT350 #1482
69 Eliminator 428SCJ
97 Cobra
86 SVO
My 68 GT350. 347 kit. AFR 185 heads. Compcams solid lifter. 1.7 Shaft roller rockers. 2x4 Holley 600's on a Trans Am C60A-A intake. JBA 1-3/4 long tube headers. 2-1/2" exhaust with Flomasters.
Boss 302 oil cooler adapter plumbed to 68 Shelby oil cooler. Big Canton road race oil pan. Takes lots of Mobil1. 8, 9 or 10 qts. Forgot exactly how much. You just keep filling it until it makes the mark.
Richmond (Doug Nash 4+1) 5 speed. Ford 31 spline Traction-lok with 3.50 gears Strange forged axles.
66 Shelby rear shelf. Functional brake scoops. Battery in trunk with Ford kit. KR hood scoop.
Extra rear leaf spring (a la Trans Am team cars). Under ride traction masters. CureRide rear shocks. Versalles rear disc brakes. 295-50-15 TA's.
Poly bushings. Upper A-s lowered 1-1/2". Ball joint wedges. Monte Carlo bar. 1-1/8" front anti-sway bar. Front Koni's.
67ish T/A team front (Big Ford) brake calipers, 12" rotors x 1.25" vented rotors. Earl's "Aeroquip" brake lines.
TA lower body cross member.
AC R12 changed to R134. 3" comp seat belts. Vomit bags for passenger hanging on roll bar.
I suspect I forgot more then a few things but the important thing to remember is it's all stock.  ::)
That's the way it came, except for the 10 spokes. Someone stole the hub caps. Bastards. ;)
You don't want to know about the nitrous bottle in the trunk right?
66 GT350
Stuff I added:
Eagle 347 kit
Original heads 1.94/1.60 valves w/ hardened exhaust seats
Lunati solid cam
Scorpion roller rockers
Motorsport dual timing chain
McLeod steel flywheel
Centerforce dual friction clutch
Custom 2.5" exhaust, Flowmaster delta 40 mufflers
620 lb front springs, 160 lb 4.5 leaf rear springs
Cobra scattershield
70's racing parts still on car:
D1ZE Boss 302 block (original block toast in 1973)
R-model apron
Panhard rod
Rear sway bar (B2)
Konis
Lowered a-arms
Drivers shoulder harness
#14
1967 GT 500 modifications.
Lowered upper control arms.
Poly bushings.
1" sway bar front,  3/4" rear.
Koni absorbers.
620 coils, 185lb leaf springs, both 1" lower.
11 x 2.75" rear brakes.
Ported and polished C6AE-R heads, 2.09 stainless intake vales, 1.70 exhaust, hardened seats, spring seats, double springs, one piece retainers and positive type viton stem seals.
Roller rockers, performance rocker shafts, roller rockers, smith moly push rods, shaft and end stands, aluminium rocker spacers and ARP rocker shaft studs.
Cometic head gaskets.
Custom ground camshaft, oiling mods with screw in galley plugs, high volume oil pump, Boss 302 pick up, moly oil drive shaft, cloyes double roller chain. Polished beam and shot peened rods, ARP rod bolts, forged TRW pistons, curved factory distributor with a Pertronix II unit, Holley performance mechanical fuel pump. Balanced rotating assembly, Cobra T-sump pan, Hooker Supercomp ceramic coated headers, Centerforce Dual Friction Clutch, aluminum flywheel.
Flowmaster dual exhaust, original Shelby extensions and lots of chrome under the hood.
17X7 10 spokes.( factory 15×7 put away)
I wired in Cougar factory electronics for sequential tail lamps. (Never again will I take something of that nature on)
I think that covers the majority of the mods)
