What did you do to your 1966 Shelby today?
Started by FL SAAC, January 12, 2024, 11:54:07 AM
Use a socket to tap boot on to tie rod,  I think I am one of those bonafide mechanics or as they are called today techs
And remember kids, cardboard is your garages floors bestes friend
Took these McNasties OUT and put in original type sway bar links and strut rod  bushings
What fun this is !
Marcus Aurelius
Our Pronouns are We Won
Bring on the tariffs
Usque Ad Finem
Well replaced a old fan belt on our 1966.
Got one on sale from $33 to $14.68
I have been told its not correct. But it has a Ford script and numbers on, looks pretty kool. Think the correct number is C5OE-8620-K. This belt has C4TE-8620-S
Maybe this was a over the counter  Ford replacement at one time or maybe two times?
I guess you can get some paint thinner and take the numbers off if they bother you a lot. To me they are fine, turns that blade around to cool the car.
Belt is made by the original manufacturer that these cars brought "Goodyear"
Pretty easy two nuts to loosen on the alternator.
Going to start making videos soon
Till then tootles  !
Marcus Aurelius
Usque Ad Finem
deathsled
Just drove out onto the driveway for a wash and carnauba wax beginning...now...
Engine revving to disturb
Quote from: deathsled on May 06, 2024, 04:47:15 PMJust drove out onto the driveway for a wash and carnauba wax beginning...now...
Gota post a picture or video. Or it did not happen....wax on....wax off
Marcus Aurelius
Usque Ad Finem
S7MS427
Finished sorting out the ATF leak into the coolant.  Pictures coming to my website.
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
If I haven't told you "great job on that website"
Marcus Aurelius
Usque Ad Finem
deathsled
Exhibit "A" for identification. P21S. Great wax.
Marcus Aurelius
Usque Ad Finem
S7MS427
Quote from: FL SAAC on May 06, 2024, 09:04:58 PMIf I haven't told you "great job on that website"
Tony,
Thanks for the compliment, much appreciated.  I'm still writing up the procedure on how to flush the block.  There will be plenty of pictures to illustrate the process.  And instructions on how to duplicate the tooling I had to build to do the job properly.  Nothing exotic, just simple hand tools.
Roy Simkins
deathsled
Quote from: S7MS427 on May 06, 2024, 10:15:35 PM
Tony,
How to flush the block?  Information I need to know.
Quote from: deathsled on May 07, 2024, 12:17:33 AM
Tony,
There are small pipe plugs in the side of the block. They have square drive heads on them. One on each side of the block. I think they are 1/4npt threads but as of this writing, I forget exactly.
Those are the drain ports. Those can be replaced with "petcocks" like used on the radiator to make it easier in the future to drain the system.
The petcocks are more susceptible to road damage so caution should prevail with casual users.
If you flush the entire system according to the manufacturers (of the flush) instructions you really don't need to remove the block drain plugs or install petcocks.
The value of the petcocks is for removing the cylinder heads without flooding the piston cylinders. That doesn't happen for most often. You would likely need to be more of a racer where tearing down the engine often is more common.
So, in short, most should leave the factory block plugs alone.
Tony,
Dont mind you posting your procedure on here
Thanks in advance
Marcus Aurelius
Usque Ad Finem
We found a new old stock replacement carburetor.  Boy what a change in idling and acceleration.
The interesting thing is the carb it had on looked as if someone rebuilt it. Looked as good as this one.
My buddy is a ASE mechanic tore it apart could not find anything wrong.
I dont know diddly squat, but noticed that the gasket used did not match the little holes on the carbs metering bodies.
That was it.
You see I have always been the guy that walks around kinda lost and looks up and around....some will get it, most wont...
Oh the cat, he is also a mechanic that helped us
Marcus Aurelius
Usque Ad Finem
deathsled
Nice looking engine bay.  Is that an Autolite carburetor?
Quote from: deathsled on May 07, 2024, 12:02:38 PMNice looking engine bay.  Is that an Autolite carburetor?
Naaaaa it's a Holley
Thing starts right up, no choke just two kicks to the accelerator. Then purs like a kitten with solid lifters....
Marcus Aurelius
Usque Ad Finem
