Shifter plate
Started by deathsled, February 07, 2024, 01:47:53 PM
deathsled
My car is originally an automatic however now lives with a four speed and Hurst shifter. Curious what the 66 manual Shelby Mustangs have for a cover plate. I have seen a few pictures with what appears to be a floating chrome bezel. Below is the current configuration. Does it need a bezel is my question.
Engine revving to disturb
Quote from: deathsled on February 07, 2024, 01:47:53 PM
Put the floating chrome bezel on and your done. The folds of the shifter boot hold it in place.
deathsled
Bob Gaines for the win. Thank you Bob.
the chrome bezel gives it that finishing touch, makes it look more complete
deathsled
kram350
Does the boot go on top of the carpet or under?
greekz
The boot is under the carpet.  I do not think the bezel will cover the screws.
SFM 6S1134  '67 GT-350 #2339
Quote from: greekz on February 07, 2024, 04:38:30 PM
+1 Boot - carpet - plate
deathsled
Looks like I will need a different boot. Thanks for the info.
greekz
Looks like you have a Hurst shifter.  The stock Mustang shifter boot may conform to the Hurst shape so you can use the stock shifter bezel, but not sure.  If you do convert to a stock boot and bezel, you will probably end up with the existing boot holes visible.  That is unless you change the carpet.
deathsled
Quote from: greekz on February 07, 2024, 09:09:12 PM
I never cut the carpet. I put the screws through the carpeting so there may be enough carpet for the bezel to cover it.
this is what you need for the "final touch" to your cockpit
Hurst has different variants of their boot
Tomdeg
#12
I found the stock boot a little binding for the Hurst shifter. I used a shift boot and trim from a '69-'70 with the factory Hurst shifter. Fit's way better.
Tomdeg
Not sure why the picture keeps flipping. Sorry 'bout that.
greekz
Quote from: Tomdeg on February 08, 2024, 07:37:19 AM
That looks like a good solution.
