Halibrand / Kidney bean wheels
Started by Speed Six, February 28, 2024, 07:34:16 AM
Speed Six
Hi ! Would anybody know if it is possible to get Halibrand or Kidney Bean style wheels which can be put on the wire wheel hubs of an early 260 ?
I've seen one with aluminum wheels fitted, using the wire wheel spinner/nut.
Ralf
Speed Six
Since there are no replies I do assume that it isn´t possible.
Now - what size/offset of Kidney Bean wheels would fit without putting on flares ? Would those wheels be available anywhere, plus hubs ? Tyres should be 205/70.
Thank you for any help.
Ralf
warped head
I was lucky enough to pick up a set of Torq Thrust wheels with spline drive wheel adapters. The front are 15x6 with -22mm offset, and the rear are 15x7 with -9.5mm offset.
I haven't see any kidney bean or FIA wheels that use spline drive inserts/adapters, but was looking at these FIA wheels that would likely fit a 289 pretty well. They'd probably still stick out beyond the flares of a 260, if that's what you're looking to put them on:
https://crosthwaiteandgardiner.com/wheel-front-6-5-halibrand-fia-style-2
Hope this is helpful.
warped head
If they're going on a 260, you could potentially get 15x5 or 15x6 wheels from Vintage Wheels with pin drive adapters:
https://vintagewheelsus.com/index.php?main_page=index&cPath=15_36
Road Reptile
Hi Ralf,
I think you would benefit by contacting Mike McCluskey Ltd. He has a long history with Cobras and may be able to answer your wheel
questions. His shop contact info is:       23890 Madison St.
        Torrance Ca. 90505
                                               web site says phone (310) 375-1234
Hope this helps out. How long have you had this car?  Where are you located?
Regards R.R.
Speed Six
Thank you both for your replies. Will look into both.
The car is not with me - it is still in UK getting an overhaul for the owner. So C&G would be an option. Although I do know their pricing...(but they are really good!). I will be at Goodwood in April, they should be there, too.
Ralf
PS - I am in Germany/Bavaria.
