Wire Harness Routing - 1969 Convertible Tail Light section
Started by DP Customs, March 04, 2024, 12:39:20 PM
DP Customs
Hi,
I'm installing a new tail light harness and routing it exactly how the old one was in the car (red arrow).  It travels from the trunk, over the fender well and behind the rear window track assembly (closer to the outside sheet metal). Now that it's in there, I see that the wire that goes to the quarter-panel light is a little too short to reach (black/blue tracer). I went back to the old original harness and noticed that someone had lengthened that wire a few inches. Now I'm wondering, should the harness be routed in FRONT of the window track (see blue dotted line) to move it in closer? This would also line up the harness a lot better with the channel it runs through under the door sill. Does anyone know (or have pics) how Ford would have originally routed this part of the harness? Again, I followed the same path as the old harness but there's no guarantee that it was in there correctly to begin with.  Thanks in advance!
Are you sure the interior quarter panel has a light?
The engineering manual shows the harness taped to the quarter panel. That is behind the regulator track so it does not interfere with window operation
Quote from: Coralsnake on March 04, 2024, 04:33:55 PM
If they had interior quarter panel lights are a early late thing on 69 Shelby's.
DP Customs
It's a '69 Shelby Convertible.  Here's the quarter panel, just before I removed it.  You can see the light towards the bottom.
I am pretty sure Shelby did not move the taillight harness, so there has to be an extension.
DP Customs
Quote from: Coralsnake on March 04, 2024, 05:33:13 PM
That's what I'm starting to think too.  The harness manufacturer confirmed that it's made correctly per their specs.
Its a cougar tailight rear harness on shelbys and a little longer than mustang since cougar is longer in rear part of car than mustang.
