1968 GT350 Front End Installation pictures?
Started by Kent, March 07, 2024, 03:25:57 AM
Kent
Hello I´m looking for some helpful pictures of the correct front end installation for a 68 Shelby GT350. Including which brackets were welded and which were just with screws. Maybe someone has pictures here from a restoration. My body guy and painter has a GT350 and he calls me 100 times and it's hard to explain every detail. I was looking for pictures over google but the most are not very correct or just clones. Thanks for the help.
By the way does someone here has a Nose Top Panel which is going between the 2 headlight buckets and that has the SHELBY letters on it then for the 68 in stock with the Shelby part number on it repro or original? I would need it. Thank you....
too many times restorers put the fiberglass header  BEHIND the brackets on the nose. First pic  of red car is WRONG. Second one on the white car is correct on the bracket being under the header.
Kent
Yes that's a usual thing I see often and it don't make sense to mount fiberglass like this.
I always did it the right way and thought its wrong and was not done like this by the factory but I thought its better for the fiberglass and years later I found a concours restored one at a saac meet and found out my thinking and doing was right as they mounted it the same way like I did all the years.
By the way I need one of these top panels does someone here has one for sale?
Bill Collins
#4
Here is the page from the factory assembly manual showing the alignment to be as Shelbymann and Kent describe it. (View "T" in the drawing).
Jhockman
Quote from: Kent on March 08, 2024, 03:04:03 AM
This might be a good option.
what boggles my mind is the header brackets have a threaded extruded hole for the bolt so why would anyone mount it wrong because you would need a nut or clip on the backside to hold it in place and possibly tightening up on the extruded hole.
Quote from: shelbymann1970 on March 08, 2024, 02:56:38 PM
It's a no brainer to me. Very juvenile.
SAM83
I'm making a list of things that didn't get done or wasn't done correctly when my car came back from restoration 7 years ago and saw this discussion so had to take a look. Sure enough, I'm in violation of the fiberglass not being on the correct side of the bracket, the hardware used to secure the fiberglass to the bracket is also not correct.
Am surprised as I supplied the restoration shop with the Master Body kit from AMK which should have contained the correct part to use.
In the picture of the white car, I see a bolt used on each end of the header support bracket.  Are they both the same bolt/washer assembly?
Cannot find my catalog that contains the assembly drawing ever since I cleaned my office. Is the bolt assembly PN 378178 -52?  Picture is a little grainy.  If so, does the link below contain the correct part with correct bolt head stamping and finish?
Apologies as I cannot figure out the insert hyperlink option.
https://www.npdlink.com/product/body-bolt-chrome/167653/202914
SAM83
Thanks Pete!  I had come to a dead end in my search.
