NOS pony keys or?
Started by deathsled, May 09, 2024, 10:38:40 PM
deathsled
I found this artifact in my closet of parts with the intent to have one of them cut. I bought a long time ago say at least 10 years from some key shop in Ohio I believe. Not that it matters, but intellectual curiosity drives the question: nos or not? I take it that the rectangular head means ignition key while a key with rounded ends would be for the trunk? (So both are ignition that I have it would seem.)
Engine revving to disturb
Period correct OEM Ford keys typically have an 'H' stamped on them.
deathsled
Appears to have. Thank you for that detail.
deathsled
deathsled
I had one of my "nos" H designated pony keys cut using the original Ford key as the template and it won't turn in the switch  I looked at the cut job and it is spot on.  I am surprised that tolerances on the ignition tumblers are that refined.  I will bring it over to the key cutter and they said they would take a look.  Thank you everyone for your observations.
Try pulling the key out of the tumbler a 1/16 of an inch and then turn
Some where I have about 10 sets of those left that I bought about 35 Years ago when I owned "TALLAHASSEE MUSTANGS, Inc."
deathsled
Quote from: Coralsnake on May 19, 2024, 03:47:28 PMTry pulling the key out of the tumbler a 1/16 of an inch and then turn
I tried but to no avail.  Thank you for the suggestion though.
NC TRACKRAT
Usually, a good buffing the "teeth" with a fine wire wheel will solve the problem.
5S071, 6S1467
deathsled
Drove the Shelby down to key key shop this morning and the proprietor happened to be there.  He looked at the key cut by his apprentice and concluded that the grooves were cut a little too deep.  I gave him the one remaining NOS blank and he cut it to perfection.  That key works perfectly.  Strangely enough the defectively cut key still works in the locks.  The case is closed.  NOS pony keys work when cut by a skilled key maker.
Quote from: deathsled on June 03, 2024, 06:13:05 PMDrove the Shelby down to key key shop this morning and the proprietor happened to be there.  He looked at the key cut by his apprentice and concluded that the grooves were cut a little too deep.  I gave him the one remaining NOS blank and he cut it to perfection.  That key works perfectly.  Strangely enough the defectively cut key still works in the locks.  The case is closed.  NOS pony keys work when cut by a skilled key maker.
Glad to hear all turned out well.
I also acquired some N.O.S. key blanks ignition and trunk for our 66 GTH.  That was the easy part.
Had to hunt down in the tri-county area who still had the old style cutting machine as all the other machines are only found in museums today.
Got some spare made, all is well in Floridaland.....click
Marcus Aurelius
Our pronouns are We Won
"Usque Ad finem"
deathsled
Quote from: FL SAAC on June 03, 2024, 06:29:34 PM
Not too many of the old guard left for the old ways. Not just key cutting.
