OIL FILL ON A 428 CJ
Started by Steve Meltzer, May 30, 2024, 06:41:38 PM
Actually, it will hurt to run too much oil.
Your motor may experience oil burning, fouled spark plugs, and increased emissions.
Not to mention leak from increased pressure
Fellas everyone is missing the point.
Everyone is talking about 1968 or 1969 or 1970.
Ford was talking about the FE motors and they put out that TSB in 1969 essentially stating :
" Oil pan levels have been revised on subject engines from four quarts to six quarts "
That's a better statement than :
" We may or may not have a oiling problem in the FE motors "
If you drive it like Granny, you are OK.
If you drive it like we all do, you are not OK.
Ford has a better idea ... just add oil !
Home of the "Amazing Hertz 3 + 1 Musketeers"
I am certainly not a Shelby Expert
427heaven
Good thing this is not a school test... Or rocket science- :-[
Lincoln tech
Quote from: 427heaven on June 02, 2024, 11:01:13 AMGood thing this is not a school test... Or rocket science- :-[
To some it is  :) Simple oil change becomes a soap opera  :o
Steve Meltzer
For some reason, the website has not notified me of the ongoing and most interesting discussion about what I thought was a straightforward question, regarding the oil change in my KR. The car is a correct and original CJ with A/C and oil cooler. My plan was to put in 5 quarts, drive it, and recheck the dipstick. I always like to drive my car "granny style" until I know she's fully warmed up, and then some modest, spirited of driving, but only for short runs, followed by cruising. In Houston Texas there's not much place to really drive, so it's not uncommon to have a bit of stop and go traffic. Thanks for all the information. Much appreciated Steve..
Quote from: Steve Meltzer on June 03, 2024, 10:24:50 AMFor some reason, the website has not notified me of the ongoing and most interesting discussion about what I thought was a straightforward question, regarding the oil change in my KR. The car is a correct and original CJ with A/C and oil cooler. My plan was to put in 5 quarts, drive it, and recheck the dipstick. I always like to drive my car "granny style" until I know she's fully warmed up, and then some modest, spirited of driving, but only for short runs, followed by cruising. In Houston Texas there's not much place to really drive, so it's not uncommon to have a bit of stop and go traffic. Thanks for all the information. Much appreciated Steve..
Look, your dimensions are not different than mine as we both have 428 CJ engines(SCJ but the same oil wise to a dip stick). I'd use the excellent reference on the 428 CJ forum on having the revised dipstick or remarking your current one.
Quote from: shelbymann1970 on June 03, 2024, 01:04:43 PMLook, your dimensions are not different than mine as we both have 428 CJ engines(SCJ but the same oil wise to a dip stick). I'd use the excellent reference on the 428 CJ forum on having the revised dipstick or remarking your current one.
Huzzah a BIG PLUS ONE !
Unless I am missing something you have a 1970 Shelby and Steve has a 1968 Shelby. Steve's engine does not have a windage tray. Yours does. Therefore the information at the 428CJ website will apply to your car. Steve has a 1968 Shelby so the service bulletin does not apply.
And dipatick has different line markings and easy way to tell is 67-68 has FOMOCO stamped. 69-70 windage tray cars have FORD stamped.
