1969 GT500 air cleaners
Started by Coralsnake, June 14, 2024, 09:29:38 AM
Are there different styles used on Shelbys?
As in regular production cars compared to regular Mustang or through out 69/70 Shelby regular production?
Just focusing on the 69 Shelbys (not including the special mods for the 70 California cars)
Quote from: Coralsnake on June 14, 2024, 12:25:57 PMJust focusing on the 69 Shelbys not including the special mods for the 70 California cars
So differences of Shelby air cleaners during 69/70 production excluding CA cars?
Yes, I suspect there a couple different ones?
Quote from: Coralsnake on June 14, 2024, 12:31:55 PMYes, I suspect there a couple different ones?
Other then the hole added in the bottom for the added different choke valve after aprox feb 1969 I am not aware of any nuance differences in the base. I wouldn't be surprised if there were.
Just those two as to noted by their engineering numbers
crossboss
Quote from: Bob Gaines on June 14, 2024, 12:46:46 PM
Yes, the Ca. cars had a hole/hose to the charcoal canister on the passenger side. IF the cars were sold after January 1970, and or for all 1970 models.
Past owned Shelby's:
1968 GT-350--Gold
Current lifelong projects:
1968/70 Olds 442 W-30
Quote from: crossboss on June 14, 2024, 11:53:33 PM
CA was excluded by the OP if you read all of the posts.
I believe I have two of these air cleaner assemblies
Marcus Aurelius
Our pronouns are We Won
"Usque Ad finem"
There is the early type flat base c8oe  68 69 then in feb 69 on into 70 428 cj c9zz had the  rear hump indent just above throttle cable and kick down rod if a c6 automatic and i always thought the hump was stamped into base for more clearance for new 69 automatic kickdown rod as 68s never used the kickdown rod setup.
crossboss
#12
Quote from: Bob Gaines on June 15, 2024, 10:17:52 AM
Yes, I did read it. Was just expanding some knowledge to the topic my friend.
1968 GT-350--Gold
