Correct latch area bolts etc.
Started by hurlbird, June 25, 2024, 05:44:02 PM
hurlbird
as you can see im missing some bolts and the latch area needs a cleaning. Can some confirm which bolts are used here? it appears the center bolts must have a nut? the others have threads in the radiator support. Bolt design is important and colors as i want to be accurate. Thanks! -John
The two bolts shown are phosphated. The other four are bright silver.
There are no nuts, the radiator  hold down has nut inserts.
All bolts are same size as fender bolts
hurlbird
thanks. the two center bots on mine are missing nutcerts i should conclude? what about the bar finish?
hurlbird
can someone show me the nutserts I am missing (left and right of center)? I assume they must be secured in the radiator support vs. the latch bracket of course.. thanks
The nutserts are in the radiator bracket hold down
The bar is phosphate/black oxide
hurlbird
thanks if they are in the bracket what purpose do they serve? think im missing something.. :)
68blk500c
The radiator hold down bracket is not in your picture.  It is black painted finish and has rubber pads that contact the top tank of the radiator.  It is bolted in with the parts in your picture to complete the assembly.
Please refer to the assembly manual.
hurlbird
got it! ill need one i guess. thanks
hurlbird
i got a bracket. I assume it slips behind the radiator support and in front of the radiator? This is a standard Mustang part? thanks
Quote from: hurlbird on July 03, 2024, 03:38:03 PMi got a bracket. I assume it slips behind the radiator support and in front of the radiator? This is a standard Mustang part? thanks
Yes. Standard 67/68 Mustang part. You got this. :)
Just as a mention there is an early 67 version that was modified for later use. Original design was thought to damage the radiator according to Ford TSB. Modification was to round the corner edges a bit
hurlbird
im finishing things up and have a few questions more please... The latch and the bolts that hold it in place should all be black phosphate. Correct? I see topflight cars with these bright silver. The bolts that support the grill "chicken wire"... What color are these supposed to be? Or a link to correct engine compartment would be awesome. Thanks..
Quote from: hurlbird on July 04, 2024, 09:14:30 PMim finishing things up and have a few questions more please... The latch and the bolts that hold it in place should all be black phosphate. Correct? I see topflight cars with these bright silver. The bolts that support the grill "chicken wire"... What color are these supposed to be? Or a link to correct engine compartment would be awesome. Thanks..
Re read reply #1.
hurlbird
Yup saw that as noted. What about the others that hold the mesh? I understand the latch area. thanks
