Little Red
Started by Coralsnake, August 17, 2018, 08:33:02 PM
TransamEd
And the VIN is 7R01S138822?
Did somebody take a better pic?
Sixx7shelby
Quote from: TransamEd on August 19, 2018, 01:51:11 PM
It doesn't look like there is any holes drilled in the apron where the Shelby tag would have been. Does #100 and #139 have Shelby tags?  Also, did they stamp the Shelby vin in the right shock tower apron of all of production cars or did some of the early cars not get Shelby vin stamped?
67 GT350 #1482
69 Eliminator 428SCJ
97 Cobra
86 SVO
Quote from: Sixx7shelby on August 19, 2018, 02:03:24 PM
Yes #100 and 139 had the Shelby tags and the apron stamped Shelby VIN . It was typical for production cars to get the apron stamped too.
67411F--0100-ENG.
Hello,
Please see the attached photos of 0100.  The first photo is an enlargement of part of a photo that was taken by Motor Trend of 0100's engine compartment on 12/12/66. The second photo is an enlargement of part of a photo that was taken by Sports Car Graphic of 0100's engine compartment on 12/9/66.
Eric
Sixx7shelby
Thanks Eric and Bob for clarifying that. Am I just not seeing holes where tag once was?
67 GT350 #1482
97 Cobra
86 SVO
69mach351w
I'm seeing 7R01C,  don't look like any "S" i've ever seen ???
Quote from: Sixx7shelby on August 19, 2018, 03:10:12 PM
Apparently Little red didn't get a Shelby vin tag because there doesn't appear to be any holes for the rivets.
Richstang
Quote from: 69mach351w on August 19, 2018, 03:30:34 PM
That's just a bad picture...
The previous link in this thread to Brian Styles unveiling photos shows it is an "S". We can see it is heavily stamped compared to the rest of the letters.
1967 Shelby Research Group
www.1967ShelbyResearch.com
Quote from: Richstang on August 19, 2018, 04:31:09 PM
+1 Its just a bad angle. One reason you always take multiples
The engine code stamping matches other indicators/details you can see in other pictures
Chris Thauberger
 Is it just me or is the rad support top rubber strip screwed on?  ;)
Chris
Previously owned:
1973 Cougar
1968 Mustang coupe
1966 Mustang 4 speed vert
1965 Mustang coupe
1968 Cougar
1971 Montego
1968 Torino GT
1966 GT350H clone
There are no holes for a Shelby VIN tag present
It is held on with small rivets and washers.
Interestingly, there appear to be two side rubber strips to seal the radiator to the opening. They have the same rivets.
I will be posting some more pictures soon
Quote from: Chris Thauberger on August 19, 2018, 05:10:06 PM
The seal also has witness marks/holes for the staples so it may have been removed and reattached with they modified the radiator opening and attached that non- Ford seal
67_1183
The VIN is plainly visible in this link previously supplied in this thread, but if it is hard to see here is an enlargement.
https://drive.google.com/drive/folders/1cCpl5RvGfYxI55MLnTGNoMLaXxG81w
Side-Oilers
Only 187 miles from Weatherford to Pittsburg, TX.
Current:
Previous:
1970 Ranchero GT 429
1969 LTD Country Squire 429
1963 T-Bird Sport Roadster
1957 T-Bird E-model
