Early 5 bolt HIPO 289
Started by paul, July 06, 2024, 05:00:25 PM
paul
Just finished but my plans have changed.
Complete, run on test stand, ready to go.
BLOCK:C4OE-60150, HIPO sequential number 1857, dated 3H27
HEADS: C3#d, dated 3H15/3F6
BALANCER; C3OE, dated G3
CARB: S2MS-9510-A, LIST 3259-1 Holley 715 CFM dated 993
INTAKE: S1MS #d small lettered 'COBRA' with part# and firing order
OIL PAN: S1MS #d 'COBRA' aluminum T oil pan
VALVE COVERS: BUDDY BAR, 'COBRA' open letter with baffles removed
DISTRIBUTOR: Motorcraft dual point mechanical advance
Low profile roller rocker arms, Isky solid tappet camshaft and lifters,
Water pump to bell housing, clutch and pressure plate.
I can substitute an original COBRA roadster cast aluminum oil pan for T oil pan currently on the motor.
$18,000. Paul Marvin, 817-691-0159, paulrmarvin@icloud.com .
