Correct COBRA Emblem placement on the fender?
Started by Kent, July 31, 2024, 05:18:31 PM
Kent
Can someone here please measure the placement of the COBRA Emblem on the Fender? I know it should be 2.25"-2.5" from the highlighted section of the fender but I can't find any data measured from the door or front of the fender and the bottom. Thanks for helping me out for the final touches. Thank you.
Kent
I dont think that measurement is correct.
Maybe someone will have a better idea
Quote from: Kent on August 01, 2024, 03:17:26 AMSorry yes the normal GT350/500
Since I have original paint and emblems on my GT500 I can measure right now where they are mounted but not the actual holes until I remove my emblems which I will do when I take my fenders off the car and push from the back side but that could be a while.
68blk500c
68 500 measurements are provided in a previous topic; try a search.
Corey Bowcutt
For what its worth here are the measurements from my car.
Corey
Kent
#7
Corey you are the best, that's what I was looking for. Is it the original fender? Thank you.
Maybe Shelbyman1970 can also check his measurement to verify.
Corey Bowcutt
Kent,
I do not know for sure if it is original.  The date stamp in the fender is washed out and filled with paint to the point I cannot read it.
Corey
azdriver
Emblems are off my car so I was able to measure the hole locations. This is passenger side.
Top hole is 6 5/16 from edge, 3 7/8 down from body line in fender (tape curved to fender, not straight line)
Lower holes are 5 1/4 and 7 3/4 from edge and 6 5/8 down from body line.
Pat
Kent
Just to make the thread better and maybe coralsnake wants to use these infos here some pictures of original holes in original 68 fenders.
Kent
Last picture is the top hole (head of the snake)
Thanks to all helping to make this thread.
