67 gt500 shock tower reinforcement plate
Started by Jeb67, August 12, 2024, 07:39:30 PM
Jeb67
Hey all I have an early 67 gt500 that has shock tower reinforcement as 68 and on big blocks came with from ford, should or did shelby weld reinforcement plates in originally?
S7MS427
I think you'll find that those were installed by Ford for all 390 CID cars.  GT500s started out using that chassis.
Roy Simkins
1966 G.T.350H SFM6S817
1967 G.T.500 67400F7A03040
Jeb67
Thank you. One question was the reinforcement added after build as my 67 gt500 shock tower reinforcement plates are stitched welded but they are ugly, was this normal? I'm restoring mine and was wondering should I clean the welds up or leave as they might have looked like this from original build?
Quote from: Jeb67 on August 12, 2024, 10:15:13 PMThank you. One question was the reinforcement added after build as my 67 gt500 shock tower reinforcement plates are stitched welded but they are ugly, was this normal? I'm restoring mine and was wondering should I clean the welds up or leave as they might have looked like this from original build?
Your restoring not "making a better car" so confirm what your seeing is original then move on to another detail. With a 67 there are plenty that will need your attention  ;)
The reinforcement plates started to be used by Ford midway in the 1968 model year. Around March 15 1968. Your 1967 GT500 should not have any such thing.
For your and others comparison
67 San Jose reinforced shock towers
Discussion on CMF https://www.concoursmustang.com/forum/index.php?topic=18735.0
68 S and R code shock tower reinforcement examples
69 & 70 styles You should be able to see the difference when compared to 68's and each other
Kent
Quote from: Royce Peterson on August 12, 2024, 10:40:39 PMThe reinforcement plates started to be used by Ford midway in the 1968 model year. Around March 15 1968. Your 1967 GT500 should not have any such thing.
That's right, and the messy welds on the 67s are not always there on the 390 mustangs.
Jeb67
I'd like to thank all of you for the info and photos for reference as well. You're correct there are a lot of issues to be resolved in this restoration if to do correct.
azdriver
Just to add to the discussion, my 3/14/68 built GT500 does not have the extra plates...
Pat
Contrary to popular belief the reinforcement plates are not "big block" only.
During 1968 its unusual to see GT500s with them and you will find them on GT350s
