1969 Shelby and mustang parts
Started by kasearch@ix.netcom.com, August 23, 2024, 02:17:34 PM
Many changes and additions to previous post - which has been removed.
Since completing the build of my 69 Shelby GT500, I now have a lot of extra components left over that may be of use to some of you, and want to make you aware that they are here. on the 1969-70 Shelby GT front fenders with headlight buckets, these fenders are in rough condition.  They have been fixed prior to my getting them, but the quality of repair is poor.  The exterior cosmetics is fairly decent, but the underside is sloppy.  Some cracks are still evident, but it is pretty much all there (fenders are complete but buckets need help). I'm not sure if anyone is interested, but thought that I would make them available before I finish turning them into wall art.  I will not be able to box and ship (old age finally caught up). Parts are located Atlanta.  If interested, please PM.
A new addition to the list
Front Valance                   S9MS-17626-B                      $150.00
Supplier code   BR= Branda,  SD=Scott Drake, CJ=CJ Pony, DN= Deadnutson, SA= StangAholics, NPD, AMK
item                         ford p/n                supplier P/N                   price/set
SHELBY ONLY
rr spoiler trunk lid lace end cap ONLY (2)   SHELBY   STLS5                   BR    $100.00
Fastback rear qtr S-H-E-L-B-Y Emblem (2)   SHELBY   SE24                    BR     $22.00
exhaust collector mounting kit     hdwr              SHELBY   CMK1                    BR     $15.00
grill (shelby)                              hdwr            f-1215               amk      $7.00
junction block@ RH apron (shelby)  hdwr           SHELBY   f-1430                  amk      $1.00
valance (fr)  -              hdwr                   shelby  f-1500                  amk      $6.00
grill moulding & emb          (shelby) hdwr (2)      f-1507                  amk      $5.00
headlamp doors (shelby)      hdwr      SHELBY   f-1518                  amk      $4.00
Fenders w/buckets  L/R        $950.00 for BOTH
1969 Mustang/Ford
hood springs   C3OZ-16789-A   MA38636                                           SD     $20.00
Turning Signal Lever               C7ZZ-13305-A   S7MS-13305-A              SD     $12.00
radiator mount pads (4) UPPER/LOWER   C9ZZ-3513   3513                      sd     $12.00
door handle hdwr   C9ZZ-6323266   SDKC9ZZ-6323266                           SD      $2.00
radiator mounting insulators          C3AZ-8125   8125-A                    NPD      $8.00
INSULATOR, COIL SPRING,  (2)                      38458                     NPD      $10.00 EACH
BOTTOM OF DOOR SEAL                              9324-2C KIT               NPD     $15.00
flywheel ring gear mount bolt    (2 avail)      6379-1                    NPD      $1.00 EACH
battery tray reinforcement plate   C9ZZ-16060-AR   10769-1B                  NDP     $25.00
space saver bottle spring           C8ZZ-A7AA9-AR   17199-AR                  NPD     $10.00
Seat back panels with clips - BLACK  (2)      60762-3a                  NPD     $35.00
courtsy Lamp @ door  hdwr                      #2457-5A                  npd      $3.00
A/T manual brake pedal                                F-1043                  npd      $7.00
valve cover washer kit      55-57 t-bird      t 6583-1K                 npd      $2.00
COWL VENT SEALS                           C9ZZ-6501999    01960-1A                      $8.00
export brace                                      16A052-1A                     $40.00
cowl to shock  brace                              16A052-8A                     $60.00
door panel clips     (15)                          hw150                  CJ      $2.00
dimmer switch grommet                                  10782                  CJ      $1.00
Radiator cap                            C7ZZ-8100-A         RC4     (13)         CJ?     $10.00
outer Shock Tower Cover     2 ea                  M225R            Auto Kraft     $40.00
Glove Box Lock W/keys  for 69-70   C6DZ-6506072-AL   C6DZ-6506072-AL             SA     $15.00
Alternator pulley                      C9AF-10a352-6   AL2021                      DN     $32.00
Driveshaft U-Bolt Kit                                  f-1273     DS1030       DN      $9.00
metra antenna 44-ul10   AFTER MARKET                metra 44-ul10                     $10.00
power steering bracket                      c7za3a652a                                $50.00
drive shaft 52 1/2 ctr-to-ctr                                                  $100.00
BOTTOM OF DOOR SEAL                   C9ZZ6520272-A         WS 76                 br     $8.00
rear door glass vertical weather strip                   ws 133                 BR      $8.00
light weight hood spings                            HS-2                   BR     $25.00
fuel tank sending unit   for 20 gal. tank           GTSU6                  BR     $18.00
door panel clips           C70Z8124/8125                RADS4                  BR     $10.00
WINDOW MOUNTING BOLT GROMMET                           RBBP1                  BR      $2.00
AC compressor field  hdwr   C5ZZ-16763                                       BR      $3.00
bottom of door seal   C9zz-6520272                        WS-76                  BR     $10.00
REAR lICENSE PlATE lIGHT SHIElD                          WS-131                  BR      $3.00
Quarter Panel Extension Seal    C9ZZ-6527802-C               ws-114                  BR      $3.00
BLACK seat backs with clips  2 each                    SPB2                  BR     $35.00 EACH
rear of splash shield support brackets    C7ZZ-16256/7-A        MSS23                  BR     $10.00
hood latch and catch     hdwr                      f-158                 amk      $4.00
Cowl braces  (70Z B429 ONLY)    hdwr   BOSS 429 ONLY        f-261                 amk     $15.00
radio - hood ground                                   f-427                 amk      $3.00
heater box > firewall           hdwr                      f-431                 Amk      $4.00
ac compressor - 390/428   hdwr                           f-713                 amk      $6.00
ac idler pulleys  390/428   hdwr                   f-722                 amk      $7.00
wiper motor        hdwr                                  f-733                 amk      $4.00
wiper arm pivot cowl panel  hdwr                    f-944                 amk      $5.00
taillamp wiring ground     hdwr    3 sets          f-2956                 amk      $1.00
Fredzer
Quote from: kasearch@ix.netcom.com on August 23, 2024, 02:17:34 PMMany changes and additions to previous post - which has been removed.
SHELBY ONLY
1969 Mustang/Ford
Fredzer
Hello. Live in Florida about 5 hrs away. Could you send some pictures of the 69-70 Shelby fenders with buckets. I am restoring a 70 Shelby. I have come up to Decatur to buy mustangs parts from a guy named Hank. My cell is +18506872204 Fred Holzer
Quote from: Fredzer on August 23, 2024, 04:06:13 PMHello. Live in Florida about 5 hrs away. Could you send some pictures of the 69-70 Shelby fenders with buckets. I am restoring a 70 Shelby. I have come up to Decatur to buy mustangs parts from a guy named Hank. My cell is +18506872204 Fred Holzer
If it is Hank Huisman he is a very reputable seller.
