Gt350 4 speed, speedo driven gear
Started by bhoulis, August 22, 2018, 12:27:57 PM
bhoulis
MPC download site says C2DZ-17271-F, 18 tooth gear, for the cable gear. I have the pink gear on the transmission shaft. Just want to confirm that this is right???  3.89 gears. Thanks. Brian
zray
Are your tires the same diameter as the original tires ?
Z
bhoulis
Going with 225/60-15s. Will have to do some research tonight. Just curious but how much does each inch in diameter change the tooth count selection. B
Vcode
The CJ site has a speedometer calculator if you want to check it out.
https://www.428cobrajet.org/speedo-calc
bhoulis
Thanks Vcode. That shows the C2DZ-17271-F, 18 tooth to be the one. Thanks again for the link. Brian
texas swede
I checked the program by Bowling & Grippo and it shows 18 as well.
Texas Swede
