need help with restoring a 1969 Shelby GT500 convertible
Started by Pico88, September 15, 2024, 03:03:22 AM
Pico88
Hi, I'm a guy in italy who has been lucky to purchase a 1969 shelby gt 500 convertible that needs a full restoration. I need some tips on bodywork because there's really limited informations available here for that model and we don't want to make a mistakes. Could someone hel me out?
First, I need to understand how the entire floor pan is constructed because we are considering whether to modify the 1969 model or to use the floor pan from the 1967 convertible.
thank you
Pietro
The 1967 and 1969 floor pans are very different.
You have an expensive car and using original parts is the best idea.
The floor pan is one piece. It goes from rocker panel to rocker panel. There is a seam at the firewall and one under the rear seat
Please share some information like the VIN and some photos
RickD
There are whole lot of things to think about when replacing the floors in your convertible.  One of the first considerations is to be sure to weld in bracing to keep that body together when the floor comes out.  Whats the condition of the torques boxes and the inner rocker panels?  Its been my experience when removing a floor that lots of other things can show up that need attention; so do a thorough inspection of all of those potential problem areas and make a plan for removal/installation and get your replacement panels ordered and ready to go.
Get ready to document all of the interior parts and wiring you will need to remove or replace before you can get to the floor removal.  Not a lot of details in your post about your experience level.  Do a good online search for information about what you are going to do.  Some pretty good older publications out there on Mustang floor panel replacement.  Better yet, if you can find a professional or very experienced body guy that has done this stuff before you will be very glad you did.
Buongiorno Pietro
Just ran into your post
Wishing you the best on your project
This is another source for floor pans
FORD MUSTANG Floor Panels - Summit Racing
https://www.summitracing.com/search/part-type/floor-panels/make/ford/model/mustang
Here is an article on the replacement
Project 1969 Mustang, Part 2: Floor Pan Replacement
https://www.motortrend.com/how-to/1969-mustang-project-floor-pan-replacement/
Marcus Aurelius
Remember that our cars are mustangs
Always look for mostly mustang parts
Here is another vendor for 1969 mustang parts
Floor boards - Classic Body Parts
https://classicbodyparts.com/?s=Floor+boards&post_type=product&_year_make_model=1969%2Cford-1969%2Cmustang-ford-1969
Marcus Aurelius
Please get some advice from someone that has restored a car  before. Many of the floor pans listed above are not correct for a 1969 car. They will fit, but they are not correct.
Pico88
Thank you all for the advice. I will take my time to read them carefully and try to apply the best solution. This is the VIN of my car 9F03R480240
I am attaching some photos
Thank you.
Pico88
Quote from: RickD on September 15, 2024, 07:32:16 AMThere are whole lot of things to think about when replacing the floors in your convertible.  One of the first considerations is to be sure to weld in bracing to keep that body together when the floor comes out.  Whats the condition of the torques boxes and the inner rocker panels?  Its been my experience when removing a floor that lots of other things can show up that need attention; so do a thorough inspection of all of those potential problem areas and make a plan for removal/installation and get your replacement panels ordered and ready to go.
will be mounted on a professional jig to ensure that none of the original measurements are lost
Pico88
Quote from: FL SAAC on September 16, 2024, 11:17:14 AMBuongiorno Pietro
Buongiorno  8)
Thank you,
I'm not sure that a 69 mustang fastback complete floor pan is correct for convertible
Those are patterned after earlier floor pans and the rib design is different
Pico88
Exactly. The design of the original ribbing resembles the floor of the '67 convertible much more than that of the '69 fastback. That's why I'm confused. Someone have some pics about a 69 convertible without interiors ?
ciao amico
Spero che questa nota ti trovi bene
hai ragione, il tetto rigido in convertibile non funzionerà
ho appena usato un esempio di ciò che è disponibile
ecco perché nella mia corrispondenza sono illustrati l'anno, il produttore e il veicolo
sono disponibili attraverso molte fonti
come quest'altro venditore per una Mustang decappottabile
augurandoti il ��meglio
Marcus Aurelius
Quote from: Pico88 on September 16, 2024, 03:56:13 PMExactly. The design of the original ribbing resembles the floor of the '67 convertible much more than that of the '69 fastback. That's why I'm confused. Someone have some pics about a 69 convertible without interiors ?
se intendi entrare nel tuo veicolo in una visualizzazione corretta al 100%.
allora devi trovare qualcuno che abbia un pianale originale nuovo o usato
ancora i migliori auguri per il tuo progetto
Marcus Aurelius
Pietro, I sent you a private message
Please feel free to contact me
Coralsnake68@hotmail.com
To confuse thing even more there are two 67 floor versions
Here are some pictures of a 69 convertible from the top side.  Just like non-convertible floors if your not looking at all the different parts added/welded to them. Of course its more difficult to see the details from the interior side  :)
Haven't had to use reproduction floors but at one point guys were having to modify the reproductions by adding a different front outer panel with the different webbing.
Hope this helps
