1969 FMX dip stick finish
Started by aboss4tg, August 23, 2018, 05:46:51 PM
aboss4tg
Okay, getting the motor dropped in today with the FMX, need to know what the finish is on the dip stick. Natural, painted or ? The tube is a Robins Egg color so we have that painted and installed.
Would like to post current pictures but seems a little difficult. Any help would be appreciated.
69 GT 350 Hertz
66 Convertible C code
66 Fastback A code
88 Saleen
89 SSP
kjspeed
To post pics, see if this works for you:
Reply to the thread and then click on "Attachments and other options" under the main post body. Under "Attach:" use the Choose File to browse your computer for the file you want. You can click "(more attachments)" under that to add a total of 4, then Post.
If that doesn't work you'll have to do it the long way: http://www.saacforum.com/index.php?topic=206.0
1968 Shelby GT350
1968 Mustang GT S-code
2009 Mustang Bullitt
Quote from: aboss4tg on August 23, 2018, 05:46:51 PM
Robin's egg blue is a very accurate description of the correct 69 GT350 trans dipstick.
aboss4tg
Car is getting closer, these are from a few weeks ago. Now have the front suspension on and on four wheels. The valve covers are not correct, just a set used for the photos.
69 GT 350 Hertz
66 Fastback A code
88 Saleen
89 SSP
aboss4tg
A few more photos. Car is running now and working on the small details with your help from the Forum.
69 GT 350 Hertz
66 Fastback A code
88 Saleen
89 SSP
Quote from: aboss4tg on October 08, 2018, 05:46:09 PM
With that said I thought I would mention that the lower A/C compressor bracket was not painted black but bare cast iron color. Positive battery cable is not ether with that red rubber cover. comments meant in a helpful way.
aboss4tg
Comments and any help are appreciated. These are easy to fix before everything is assembled.
On the battery cable, what is correct? The set I purchased came that way from the vendor, NPD.
69 GT 350 Hertz
66 Fastback A code
88 Saleen
89 SSP
cj750
I was under the impression it should be this style:
Every post I make comes with an implied request for corrections. I'm here to learn.
Ldouble619
I'm still learning, but I believe the oil filter should be engine blue.
Quote from: cj750 on October 09, 2018, 01:42:06 PM
Yes, that is the 67-69/70 Shelby style. Also a preferred orientation of the positive and negative cable. Sorry for the fuzzy illustration out of the 69 assemblyline manual but you can get the idea.
Quote from: Ldouble619 on October 09, 2018, 05:23:14 PM
It depends on if you are trying to restore to a point before the first oil change or after. A later filter after the first oil change would be a Autolite FL1 . The filters were block color blue from the mfg for assemblyline installed filters. They were not painted on the engine .
SNAKEBIT
Mr. Gaines, as usual, great input. So, the positive cable he has is incorrect or just its position according to the assembly line manual? Does anyone make a copy of the assembly line filter? I guess, as long as you have an Autolite FL-1 it will look correct.
Waitin' for the day I get my first '70 Shelby convertible!
Quote from: SNAKEBIT on October 11, 2018, 06:08:39 PM
The positive cable in his picture is incorrect. If you don't have a assemblyline blue filter there are at least two ways to approach the problem. You can take a original  FLI Autolite filter and paint it Ford engine blue . You can also take a reproduction FL1 filter and paint it Ford
engine blue .
SNAKEBIT
What are the correct cables for a '69-'70 model?
