Build Dates
Started by JohnnyQuest, August 24, 2018, 05:06:55 PM
JohnnyQuest
Redundant I'm sure what are the approx. build dates? I haven't looked at the block, I'm lazy.
My invoice date was 2/9/66.
Thanks!
zero
Looking for another 2008 Red KR
GT350Lad
Hi, not sure about yours but my car was scheduled to be build at Ford's San Jose, CA assembly plant about the 19th of October, 1965. Got that info from Howard.
Cheers
6S373
6S1276
If you provided the first three digits of your Ford sequential number a ball park guys at what Ford/Milpitas guessed would be the completion date. With more of the sequential number the closer to that number could be figured out based on other cars entered into the system around the same time.
Could make a guess just based on your Shelby number but that would possibly not be the best option since I can't tell what the Ford VIN is though I could guess
Of course that was only a guess made by an employee when the order was received and could be off by weeks in either (earlier or later) direction.
Another method is to find and list every possible sheet metal date that makes up the unibody (welded on not bolted on) and use that to help get a better educated guess at the possible real date the car may have been completed at Ford
Karguy
It would be interesting to see what the stamped production dates are on your steering box tag and on your left front inner fender. Those are the dates that are the latest on 281 and definitely close to what I believe the actual San Jose build date was, somewhere between Oct 6 and Oct 15.
Karl
Karguy
 After a very good discussion with a very knowledgeable guy , (Jeff)  I have adjusted what I believe to be the actual San Jose build date for 6S281.  The latest date stamp on my car is October 5 65 which caused me to set the San Jose date between October 6 and October 15. What I was not aware of is that the parts for these cars were stamped in Dearborn which means once produced they still had to travel to the San Jose plant For use in those cars. I now believe 281 was built at San Jose somewhere between the 11th and 25th of October of 1965. The SAAC form is truly an amazing resource for all of us Shelby and Mustang nerds, where else could you find this information but from the very knowledgeable people who generously participate?
JohnnyQuest
FORD vin is 113,xxx. Tried without luck finding the number through a FORD production number book but couldn't get my hands on one.
Stampings are a good idea though...
zero
Quote from: JohnnyQuest on August 25, 2018, 04:34:41 PM
San Jose would have likely assigned a date of  Sept 31 (30J) to the door tag based on other Mustangs with a similar sequential number
Yes date stampings would be a better indicator IMHO. Might want to swap notes with Karguy
GT350Lad
#7
My car is also a 113xxx baby, so you can email me. Got some dates codes written down; steering box etc
Cheers
6S373
6S1276
#8
Hi Johnnyquest,
The San Jose estimated scheduled production date for a 6R09K113XXX VIN, based on the attached chart would be very near the end of September (like Jeff said) or the beginning of the month of October 1965, the 1st or the 4th (Assuming no work on the weekends).  This estimated scheduled build date should be balanced against the all the date codes and  especially the engine assembly date.  It is likely Ford was running behind and the actual build date could be closer to the middle of October.  You can also used the HiPo registry to estimate the scheduled build date from other cars with near Ford VIN's.  Do you have a copy?
Hope this helps.
Karguy
#9
 Strictly for reference, there was a San Jose built 66 K code fastback (not a Shelby) for sale on eBay about a year ago, Vin number 11376#, it was built September 30, 1965. Its engine build date was Aug 27 65.
Karguy
Hey Jeff,  i've been poring over 1965 September and October calendars recently so I noticed this in your last post on this.
"San Jose would have likely assigned a date of  Sept 31 (31J) to the door tag based on other Mustangs with a similar sequential number"
There are only 30 days in September, Not sure that it really matters but would Ford likely have assigned a date of September 30 or possibly October 1?  :)
SFM6S087
It's my understanding that the ASSIGNED (or scheduled) build date is what would be stamped on the door tag on a regular Mustang. And those are the dates that will be found in the HiPo registry.
But the ACTUAL build date could be weeks before or more likely after the assigned date. Thus creating the need to check any dates you find on paper against the dates you find stamped into the sheet metal on your car.
I mention this in particular because I've seen people who believe the dates found in the HiPo registry are actual build dates. They're not. They're the dates people sent in from their door tags – i.e. assigned/scheduled production dates – not actual production dates.
If any of the above is wrong, please correct me.
Steve
JohnnyQuest
Great information, no don't have a copy of the Hi-po registry.
Thanks, JQ
zero
Quote from: Karguy on August 26, 2018, 01:52:32 AM
Slip of the finger corrected it above - but yes guess it could be either. There is a gap in the data with a number of known Sept 30 and no Oct 1 reported but yes could be either - though it doesn't really matter since its only a rough guess/estimate from a data entry person
Quote from: SFM6S087 on August 27, 2018, 04:17:24 AM
Steve
Believe you are correct
