69 Center Caps , Authentic???
Started by brandosaac, November 22, 2024, 07:26:16 PM
brandosaac
Im not too familar with 69-70 shelbys
I have a set of center caps , trying to determine if they are originals or repops.
They are plastic and have CCPC S9MS-1130-B number on the back .
 I noticed that Scott Drake / Holley offers a reproduction (catalog part number S9MS-1130-D) , But im not sure if those scott drake ones have any numbers on the back?
thanks
Quote from: brandosaac on November 22, 2024, 07:26:16 PMIm not too familar with 69-70 shelbys
I have a set of what appears to be NOS center caps , trying to determine if they are originals or repops. they are plastic and do have S9MS.... numbers on the back
thanks
I have some in the blue and white Ford service marked boxes with the green epoxy and also ones in the plastic sealed Ford service marked plastic bags with the green epoxy. The repros are typically a different color epoxy. With that said once mounted most of the good repros I have seen are good enough to pass for Ford inventory.
brandosaac
thanks for the info Bob.
If you get a chance, can you tell me if yours have the same numbers on the inside back lip?
I plan on selling these and id hate to advertise them as originals if by any chance they are not
Quote from: brandosaac on November 25, 2024, 02:10:14 PMthanks for the info Bob.
Yes my caps all have the extremely hard to read and small engineering numbers made into the  perimeter upper edge of the plastic mold . The ones that the metal mounting clip frame doesn't obscure you can read. Others are mostly obscured by the metal.  I would be surprised if the repros had that. I think that you can safely say that they are original if they have the engineering numbers . Best of luck with your sale.
The old originals and assembly line type have black glue if i remember correctly
Shelbypat
Here a NOS black glued with part number you can barely see.
Patrick
Patrick
Canada
