65 Fastback project
Started by Bill Collins, November 24, 2024, 04:33:20 PM
Bill Collins
'65 fastback that started life as a Poppy Red C code. Was being built into a drag car when work stopped in 2009. Very solid body with all stamped VINs and door warranty tag intact. Has a current title in my name. Would make a good basis for a replica build or drag/track car.
Engine is believed to be a modern 5.0 with various modifications but no build specs are available. Observable details include Edelbrock air gap aluminum intake, M/T aluminum valve covers, tubular headers, roller rockers and remote dual oil filter system. The engine has not been fired.
Driveline has a Lakewood bellhousing, toploader 4 speed with Hurst shifter and Lincoln Versailles disc brake rear, gear ratio unknown. Front brakes are also discs with a dual master cylinder.
The interior has a roll cage and the trunk is set up for a fuel cell.
Various loose parts come with it, including a pair of doors with fastback glass and all internal mechanisms intact, windshield and rear windows with mouldings, clean used OEM Ford metal hood, headlight assemblies, front valences and bumper brackets. Also some interior parts including front seat and rear foldown cores, dash parts and more.
$19,500 for everything. Detail photos available. If you think it's too much, bear in mind that a Dynacorn body shell with a hood and empty doors is $17,500 plus a $595 crating fee FOB in California and you don't get a VIN or MSO/title.
Bill Collins
Harrisburg, PA
717-648-6600
bill@bcfords.com
