9M4 std bore 428 short block
Started by 428kid, November 28, 2024, 09:02:43 AM
428kid
This is a very nice std bore 428 C scratch short block. Came original out of a PI car. It's dated 9m4 with no assy date stamped on it. Engine was in the original running car 30 years ago . Around that time the engine was removed and car was scrapped . I took the block to the machine shop had it all checked out . Thermo cleaned it and magged it . All things passed and looked great. Only issue to not is a very minor chip at the very bottom of one cylinder where something just kissed it but will cause no issue upon rebuild, but I have taken a photo of it. Comes with a std 1ub crank that will need turned due to flash rust from over the years and 8 C7 big bolt rods and balancer. Engine had original cam , lifters , and bearings in place, so does t appear to have ever been apart until PO removed it. Probably have timing cover and a few other pieces if that helps. $Sold picked up in middle TN or delivery to fall Columbus this Friday or early Saturday with deposit.
