67412F5A00565 on BAT
Started by azdriver, December 05, 2024, 10:51:30 AM
Was listed for sale in Hemmings January of 2021, in California was asking $215,000.00
thinkshelby
This post is me seeking to learn more about (67 and 68) Shelbys.
How should the red/orange primer parts look?  Does the answer apply equally to '68s?
It seems too glossy (e.g. photo 85).
It also looks like orange was sprayed over some uneven surfaces, and folks just stopped painting at odd places, like in photos 96 and 97 and 106 (no orange above the power steering components).
And there are different orange colors: 105.
Should my attention be elsewhere?
Thank you.
The correct color is "red oxide" primer. It was not glossy when originally applied.
You may have slight variations in the color and different parts of the undercarriage were not sprayed at the same time.
The idea was to cover all downward facing surfaces, however, some surfaces may not have received primer.
67 and 68 Shelbys were built at different plants and techniques varied
The body color, pinch welds and engine bay were sprayed after the primer and should be without hard edges, causing overspray
The forum is not allowing private messages for some reason
You can find me here
www.thecoralsnake.com
The car above is not really indicative of the factory appearance
1175
Rear shock plates mounted 90 degrees the wrong direction.  Bomb can red oxide 'refresh' leaves a lot to be desired.
Jon
Quote from: Coralsnake on December 08, 2024, 02:31:07 PMThe car above is not really indicative of the factory appearance
You can say that again. :o
Kind of getting off thread
Quote from: thinkshelby on December 08, 2024, 01:25:52 PMThis post is me seeking to learn more about (67 and 68) Shelbys.
As mentioned you should not really compare the two. Each has little to do with the other when you get to the details. Somethings similar but not the same in other words. As Pete mentioned - Mustangs were built at different plants and by different workers and the conversions - just the same - two different companies, processes, suppliers for many things ....
Quote from: thinkshelby on December 08, 2024, 01:25:52 PMIt seems too glossy (e.g. photo 85).
In my eye the floor color original had a greater shine that what most people think of. Guess its the term many used - Red Oxide - that brings up memories of Rustoleum rattle can red oxide. In this case it was an epoxy based paint/sealer and not an open (flat) primer that was designed to be over coated with another layer of paint making it more rust proof.  Now all of the over spray from the exterior body color, pinch weld black out and black wheel well and engine compartment painting each create a flatter and rougher look where there is fine or slightly more over spray on the floors and frame rails. And originally there was overspray on most of the floors from about the firewall rearward due to high flow and high pressures the guns used.
Add to all of this 50 years of age and use and the surface is flatter due to those elements also. Not saying it is a high gloss finish but you can get a light to reflect off of a cleaned original floor color both the epoxy primer sealer or a batch color used on other years and models
This might help in relationship with the 67 undercarriage. Still need to create one for 68 NJ built Mustangs/Shelbys
1967 San Jose Undercarraige Details
Quote from: J_Speegle on December 08, 2024, 09:44:52 PMKind of getting off thread
Jeff, I cannot get the link to work. I'd love to see a 68 detailed underside done.
Marcus Aurelius
thinkshelby
The link is working for me.  Here it is "spelled out" in case that's useful:
https://www.docdroid.net/dNrBoiu/article-opensource-67sanjoseunder-19v6-pdf
And Wow!  Impressive document, thank you.
(also interested in one for '68 :-)
Quote from: shelbymann1970 on December 09, 2024, 07:50:32 AMJeff, I cannot get the link to work. I'd love to see a 68 detailed underside done.
Hmmm - Just clicked on it and it loaded. A bit slow but that could be my connection or just due to the size of the file.
Posted versions in past threads for 65 and 66 San Jose as well as 69 Dearborn Mustangs based on the years that typically are in greatest demand over the years.
