69 GT500 License Plate Lamp Socket Wiring
Started by rdmgt500, December 15, 2024, 06:44:04 PM
rdmgt500
Need some help with connecting the 2 license plate lamp sockets to the wiring harness. Should the 12V contact wires from each socket be spiced together into 1 bullet connector that plugs into the harness, or should the loom have 2 female bullet connectors for each socket? Similarly, should the ground wire with the lug connector from each socket be spliced together into 1 lug terminal or should each lug terminal be connected to ground? Thanks!
Quote from: rdmgt500 on December 15, 2024, 06:44:04 PMNeed some help with connecting the 2 license plate lamp sockets to the wiring harness. Should the 12V contact wires from each socket be spiced together into 1 bullet connector that plugs into the harness, or should the loom have 2 female bullet connectors for each socket? Similarly, should the ground wire with the lug connector from each socket be spliced together into 1 lug terminal or should each lug terminal be connected to ground? Thanks!
The two bullet connectors are plugged into a special "two into one" connector that is typically yellow.That connector is then plugged into the license plate light female connector made into the taillight harness. A alternative can be made but anything else is less then assemblyline. That is if it makes a difference to you.
Or the three in one, black in color
rdmgt500
Bob, Coralsnake,
Thanks for the replies. Haven't been able to locate either the 2 into 1 or a 3 into 1 bullet spice connector. Any idea where I can find one?
rdmgt500
Quote from: Bob Gaines on December 16, 2024, 12:10:39 AM
The two bullet connectors are plugged into a special "three into one" connector that is typically Black. That connector is then plugged into the license plate light female connector made into the taillight harness.  Anything else is less then assemblyline. That is if it makes a difference to you.
I amended my post as my post to support Pete's post for the most typical black one . A Yellow 3 into one wire alternative can be found made in many under dash wiring harness's typically near the fuse box. The alternative can be easily made by adding a bullet connection to the single wire. The ground wire from the receptacles can be attached individually at the provided ground points one on ether side of where the filler neck goes through the support .
