Holley Dashpot Part Number
Started by Steve Meltzer, January 05, 2025, 04:45:00 PM
NukeGT
Looks like maybe a potential vacuum leak due to the cracked rubber cap/plug on fitting next to the coil.
Clamp on fuel filter hose should be crimped style or at least have sharp corners.
Steve Meltzer
Thanx for the info; the pictures were most helpful! Any thoughts on how I get sucha bracket? FYI, I swept that area carefully with a propane torch (Yes, Mr. Smarty-Pants, unlit!) no vac leak. thanx steve
Steve Meltzer
I found the bracket on eBay, and you say the spring is correct. So, I should be good to go. thanx steve,
