WTB PM300 Antenna
Started by rdmgt500, January 09, 2025, 10:20:38 AM
rdmgt500
Looking for a 1969/1970 Shelby Antenna (C9ZZ-18813-C)
Quote from: rdmgt500 on January 09, 2025, 10:20:38 AMLooking for a 1969/1970 Shelby Antenna (C9ZZ-18813-C)
They are out there. There are a few people selling them on ebay however those seem to be the ones that look exactly correct but they are missing the connection inside to the mast consequently they do not function as a antenna for your radio. If you only care about the look but don't care if your AM radio works then those are a alternative. You can tell the difference by looking into the coaxial port . If you don't see a center pin in the opening then you know it is the made up out of parts one that will not receive signal for your radio. It is however concours correct for judging as long as there is not a operational check.  Here is one such no signal antenna for sale. https://www.ebay.com/itm/315762891605  500.00 is the going price for these. Notice the empty hole with not center pin where the antenna coaxial cable screws in.Just want to help with info so that you can make a informed decision.
rdmgt500
Thanks for the response Bob. I saw that one on ebay. It's also missing the coax cable lead, nut, and metal strap.
I recently had the strap made 100%   correct like my original as it is unique and never serviced by ford
One of the sellers of the PM300 antenna's also sells the upper mounting hardware with special nut. You can find the Ford marked coaxial cable but you will have modify the end going into the antenna with the proper connector. Of course it only needs to look the part if the antenna is not functional anyway. That screw on end has been hard for me to find last time I looked but fortunately for me I haven't had a real need to source one. Consequently I haven't put a lot of effort into finding them. They may be relatively common for all I know.
Quote from: Bill on January 09, 2025, 07:25:50 PMI have the correct PM-300 antenna, with the proper coaxial/male pin, but do not have any of the other mounting parts, nor cable.
Bill ,this sounds like a alternative for the OP if you are so inclined.  Best of luck to both you and the OP.
rdmgt500
Found an old "Snyder" auto antenna on ebay
https://www.ebay.com/itm/174611195363
Wonder if that coax cable and connector/nut is compatible with the PM300 stalk.
Quote from: rdmgt500 on January 09, 2025, 08:48:58 PMFound an old "Snyder" auto antenna on ebay
It looks too small from my perspective.
rdmgt500
aj
Ed, do you have the antenna strap for sale ?  I need one
rdmgt500, sent you a PM regarding antenna.
Adrian Jacobs
yes do u have the loop strap that goes around the tube?
rdmgt500
No. I don't have any parts needed for the ground strap.
Bob
