GT 500 Automatic Shifter Question
Started by rbarkley, September 03, 2018, 06:42:10 PM
rbarkley
Hey Guys
Happy Labor Day!
I am familiar with the extra piece that was welded into the auto shifter, but what is this bolt for?  It has no threads at the end and fits into the small hole
in the base.  It appears to be some type of detent.  Was this added by a PO or added by SA?
Ron
Quote from: rbarkley on September 03, 2018, 06:42:10 PM
Hey Guys
Happy Labor Day!
Ron
There is a stop bolt but the one in the picture has been substituted for the original one. I believe it is tightened or loosened with a Allen key. FYI the special shifter assembly(including stop bolt) was not added at SA . It was added on the Ford assemblyline.
Quote from: Bob Gaines on September 03, 2018, 10:28:25 PM
There is a stop bolt but the one in the picture has been substituted for the original one. ............
+1  Home made fix
rbarkley
Thanks Bob and Jeff for the info!
Here are a couple of more pics.  For a homemade fix, someone spent some time adding the hex head and detailed tip.
Do you happen to have a pic of an original stop bolt?
Ron
Quote from: rbarkley on September 04, 2018, 07:59:40 PM
Ron
Guess I should clarify - sorry for any confusion on my part.
The "lock" nut IMHO appears to be added/a home made fix for the adjustment threaded section either because they were having a problem with it or someone just assumed the addition would be a better idea
The threaded shaft and insert to be like other originals I've seen. Will post a few pictures in a little while
Here are a couple of shots of one in the car you can make out the end of the insert and the cross hatch pattern (well one channel) in the outer threaded section
Hope this helps
rbarkley
rbarkley
Is that a plastic washer inside?  What is the name and where can I get one?
Quote from: rbarkley on September 13, 2018, 08:34:37 PM
Think that is a nylon bushing. Think most catalog companies carry the, try automatic shifter bushing or something similar
rbarkley
Ok.  Got it.  Two required.   Thank you.
rbarkley
Got everything back together and installed. However, I am still trying to locate the c6 shift rod.
I also refurbished the emergency brake mechanism and added a new handle.
I noticed today that the transmission has a broke bolt in it (one of the two that goes to the transmission mount)  Good grief!  Any ideas on how to get it out?
Quote from: rbarkley on September 16, 2018, 10:18:50 PM
Guess its Easy out time as a first place to start
