65/66 goodies
Started by acman63, September 05, 2018, 06:06:22 PM
acman63
65/66 GT350/Mustang Parts
Control arms - complete set restored  uppers, lowers and coil spring seats  . Restored using nice original parts,  riveted balljoints .  half and half black dipped Sold
65  Radiator 2/65 dated  4 speed.  G2  Restored with new proper core.  . early type with stamped G soldered.  pics for the asking .  Sold
NOS  Intake Manifold Gaskets $125
L5  Intake Bolts   $35  set
65 Braided Oil line $95
oil line adaptor bracket  $45
65 carb to pump line $16
66 Holley carb to pump line  - not the 67 line everyone else sells $25
66 Holley fuel filter adaptor  $40
Ray Brown Seat Belts -came on most 65s  Restored early hardware with encapsulated latches and short links, short latches with wings.  Proper Ray Brown Labels with stamped part #.  We also have the correct hardware if you have a later car or early 66
Rechomed hardware , new webbing.  original stitching replicated , Thick  leather pads $1595  pair  (2)  belts
Impact Seat Belts - virtually same as later 65 belts above but longer links and Impact labels  $1595  pair (2)  belts
T10 M  Aluminum close ratio 4 speed Transmission .  All new stronger  concours case and tailshaft housing with proper markings . M series close ratio gearset Blueprinted rotating assembly .  premium bearings,  racing cutback synchros to help from popping out of gear .  Clearanced for better oiling .  Ready to Install  $10,000.  with concours restored shifter 10,695.  shipping will be in a custom crate.
T10 Shifter -  restored shifter using all original parts exc knob .  True Cad Plated control box - shimmed with original pins,  bare metal and oiled rods  with cad plated original levers. shimmed like factory.  rechromed  handle with new cable.  New knob  $695
NOS Transmission Crossmember mount.  bare steel near perfect as Ford could get  $250
Original Disc Brake Spindles .  stripped to bare metal.  checked for cracks , black oxide coated.  bare metal areas revealed.  $450  pr.
Original Kelsey Hayes 4 piston disc brake calipers.  Concours restored Castings.  Cadmium Plated large halves.  Phosphate plated 3/8 inlet small halves.  machined bare mounting surfaces.  Plated boot retainers.  hone finished bores,  new seals , new OEM Finish caliper Pistons.  New Boots.  OEM Finish transfer tubes,  Di-chromate bleeder valves.  Pressure tested and oiled.  $650 Pr.
Original Kelsey Hayes Caliper mounting Brackets . correct 65/66 versions with markings, natural metal with machined bare areas  $195 pr.
Caliper Mounting Bolts  set of 4 proper finish and grade  $20  set of 4
Disc Brake Proportioning Valve  - Restored original .  baked , casting.  strip to bare metal.  black exterior finish, cad plated adjuster nut,  new rear plate. Di-Chromate jamb nut .  machined bare metal areas.  sleeved bores,  new seals.  $525 .
Disc Brake Junction Block - nOS  original vendor   $75
Disc Brake Master Cylinder, proper Numbers on bottom  .  sleeved , rebuilt restored  $325
Cobra Buddy Bar Valve Covers - concours restored  Sold
Cobra Black Krinkle "Fang" Covers .Sold
Cobra T-Pan  -  original for Gt350 .  S1MS Sold
NOS Air Cleaner element. orange rubber Sold
Tri-Y Headers.  Concours headers made to original specs. .  Machined  mounting flanges .  Proper 3 bolt collector flange.  Welded inside . Suaged inlets.  mandrel bent, welded as original . $995  bare steel   $195  for baked on  Metal Ceramic Satin Black Coating .  WAIT TIME ON HEADERS IS APPROX 3-5 MONTHS RIGHT NOW
Header Bolts  $35  set  recessed type
Header Bolts   Sundial originals  have 6   $300
Header bolts  Rockford  $250  set
65 side exhaust kit.  Made to original specs .  includes proper 2 inch pipe inlets  bullet mufflers, outlet straight cut sir pipes,  3 bolt flanges /Gaskets   Mounting Hardware.  Outlet Pipe Mounting kit.  Clamps.  $495    -  Concours muffler clamps add $125
66 Exhaust System - Concours with Date Coded Mufflers  - Inquire
65/66 Hipo Axles - Restored Sold
65 axle tube - reproduction  from western rust free parts,  no override brackets attached  - sold
65  Drive shaft Loop,  concours correct  $89
65  3rd member rebound plate - had some pitting and I filled them and painted -  real item  $300
65  early  9 inch Hipo  body plate that rubber bumper hits from 3rd member  $250
65  Cragar Wheel caps - concours detail painted  $400 set of 4
65/6  Hood.  we had 3 original hoods to use and made our own tooling.  correct woven cloth  contraction.  Early Venice style  $895.  next version porthole $850.
65/66 R-Model Race apron -  we had two originals to use to make our own tooling  $245.   concours version with woven cloth $295   SPECIAL ORDER!
65 Rear shelf,  replaces rear seat,  we loaned our glass man a very nice original to make these as close to original as possible   with woven cloth where visible,  cut out for plugs  and spare tire mount  or (Not Cut)  your choice  $395.
65 grille moulding center bullnose,  fully polished  $95
65 upper grille support triangular bracket , made to original specs with proper hardware  $79.95
65 Hood proper Rod .  made to original shape $75
65 side stripe fender logos -  we made these using original nos and computer cut them  with proper color  $55  pr.
66 Side stripe kit,  white , blue . $79  Hertz gold $114
65-67  / 69   Leaf spring round hole band clamps with rubber pads.  $59.95 set  Postpaid if prepaid by Paypal friends and family!
65/early 66  Koni shock special front upper cad plated  mounting bolts.  $55  set
65/66 Export brace - original bar  $350
65/66   Koni Shock bell shaped boots to cover jamb nuts  $50   pr.
65/66 Sway Bar Kit - all original bar.  brackets  with new rubbers and end links SOLD
65/66 Steering kit - Quick steering idler and pitman arms  $175
65/66 Fomoco logo Pitman arm  original assemblyline  version $200
NOS  Idler arm mounting Bracket  - concours quality  $$75
65/66 Steering box.  rebuilt detailed 4 turn $595
289 Hipo Blocks,  I have three date coded 65 blocks  -  none are standard  all were hot tanked,  baked out the grundge ,  steelbrate to bare metal.  square deck to make sure both deck heights the same ,  Bored to nearest oversize and oiled. They are either 30 or 40 over.  They are C5AE  blocks with the hipo caps.  $3,000  plus shipping. Ill try to add cast dates
NOS vent window front runner.  assemblyline version with Clear Plastic over the felt.  RH  sold
Hipo Balancer C3OE  - restored  $695
NOS Hipo Head Gaskets -  have proper small hole thats visible   $150  Pr.
63-68  cast iron intake manifolds $100-250
If you dont see it ask
920 434 3645
jim@shelbyparts.com
SAAC Concours Chairman
footnfan
kingchief
SFM 6S406
acman63
just scratched off a bunch and added some new items
