Sleeping Beauty wakes up
Started by 427heaven, January 23, 2018, 09:40:27 PM
427heaven
Thats a VERY tight fit on a Big Block car, right there! . I see where it goes, as always Thanks for the correct placement of things. ;)
Here is a useful illustration that Branda has posted on their website.
Quote from: 427heaven on September 30, 2021, 08:43:58 PM
Thanks Tony- How are things in Margaritaville? Hospital beds in the ICU are full again, out on the left coast. Be safe out there! Like the keepin it positive posts, and pics... keep them coming.
See you and sleeping beauty are progressing,  doing well. Keep plugging away !
427heaven
Thanks guys for the assistance with correctness, and the positive influence over the last couple of years, which have been very difficult on many of us and loved ones. Getting pretty damn close now ... One more question do the shoulder harness ends fit in the main seat belts or am I missing some parts?
Quote from: 427heaven on October 18, 2021, 06:13:23 PM
The 67 Shelby shoulder harness does not fit in a buckle. The harness is secured to the floor on both sides in the same place as the front lap belts. Your arms fit through each right and left loop. The inertia reel keeps you from leaning forward in a quick stop by the mechanism latching at anything more then a slow deliberate pull of the harness.
427heaven
That was the only place I could mount them, seemed wrong, but my race car belts have the shoulder harness, regular center belt, and the submarine belt all joint in the middle with a cam lock. Seemed weird that a customer back then would have to kinda wind into them, guess thats just the way it was. Thanks again for your guidance.
427heaven
A couple more original technical questions because I would like it to appear correct. Did the ground block require a ground strap to the block for the gauges to work properly or did the block ground itself to the chassis thru the mounting bolts.? Also what connection was used to mount the copper oil pressure tubing to the top of the oil filter housing something special or a standard brass T fitting? Lastly the gauges were illuminated with a nasty looking green painted bulbs, would a newer version of an LED bulb illuminate better and look better so one would not have to squint to read the gauges? Getting oooh so close now after sitting 51 years, all the boxes and containers that the car came home in are just about empty!!! THANKS TO ALL FOR THE HELP. :D
Quote from: 427heaven on October 24, 2021, 11:00:34 AM
There are two cabled grounds to the block. The negative battery cable is bolted along with a star washer into the threaded boss on the front passenger side of the block below the head . Another smaller gauge cable is bolted to the rear of the passenger side head and on to the firewall with a small sheet metal screw like what holds the regulator . The screw uses a small star washer for better contact. No copper line was used from the factory only nylon. The copper is your choice but will look like a modification.  From the factory a special steel compression fitting plated silver was used to mount the nylon tube to the top of the oil filter adapter. The same will work with copper. Your choice to change out the factory green bulbs with brighter.
427heaven
Thanks Bob for that info... So the oil line fitting was a Shelby looking part, or was an auto part sourced item?
Quote from: 427heaven on October 24, 2021, 02:59:49 PM
It was a Stewart Warner item that came with the gauges Shelby bought for the cars.
Just plate the brass one silver and be done with it. I don't think anyone except a well informed enthusiast will know the difference.
427heaven
Wishing everyone a Happy Holidays ,- Merry Christmas and be safe out there. My car is finally nearing completion so I would like to offer a very big Thank You to all that have offered a helping hand in many different ways! Could someone PM me on how to post pictures for someone that doesnt do that stuff too often.
Quote from: 427heaven on December 05, 2021, 07:48:55 PM
Look back at page 11, post #162 and click on the images, that steps you through one of the ways to post images...
427heaven
Thanks JD your always helpful... ;)
Back at ya !
