Horn wiring
Started by TLea, September 07, 2018, 11:27:16 AM
How were the original harnesses modified for the horn?
I believe they took the two wires from the harness (blue and yellow) and re-routed them to the toggle switch. Maybe someone has a picture. I can check my file tonight
cut  added butt connectors and ran new wires to switch
mygt350
If memory serves me, wires were cut and 2 yellow wires butt connected to hash mounted switch on 5S228.
Quote from: mygt350 on September 07, 2018, 01:54:55 PM
Both wires were yellow? What color butt connectors? Thank you
mygt350
As I remember it, both horn wires were cut really close to the 4 wire connector at base of column. Then yellow wire was connected to main fuse block on upper kick panel and ran to one side of the dash mounted toggle switch. Another string of yellow wire was connected to other vacant switch connector and l. Other wire, I believe yellow as well, was connected to the existing wire going to the horns. So only one butt connector would be involved. I can crawl under my dash and see if I can find the connector, but cannot guarantee its original to the car.
65Clone
This is 5s545fro another site. Hope this helps.
Quote from: 65Clone on December 29, 2018, 05:31:53 PM
that was the photo i was going to look for ..........  where is this other site with these photos?
65Clone
www.nvsaac.com is the site, then go to gallery. May have been from www.saac site on someones post. I try to keep info on when and where as there is so much hoopla on what is correct or not. Good Luck with your search, and happy to help.
Jbarela
So this thread kinda dropped off a bit, can anyone share pics of there cars horn waiting and how it connects to the main harness. What gauge wire was used? Are all examples yellow wires? How about total length of the wires themselves and how it was routed to the switch. Thanks for the help on advance.
Jbarela
#10
Well I came up with 34 inches based on the pic above, but its seems to short to me, my car is apart to even try to see if it will work. But here was a first attempt at it. Maybe someone will chime in and help with the measurment of there wires.
