Common date codes - HiPo Fan Blades
Started by 6s1640, March 29, 2025, 11:34:59 PM
Hi all,
I was curious what might be the common date codes for the HiPo 289 Special Fan blades and what might be the latest date code.  I have seen:
Stamped on blade front side:
  A65 (Input from Rickmustang)
  B65
  C65
  E65  (Input from S2MS)
  F65  (Input from S2MS)
  G65 (Input from S2MS)
Stamped on blade back side:
  J65
  L65
  A66
  C66
I expect these blades were made in batches, so it likely there is not a dated blade for each month in 1965 and 1966. What is the latest date code out there?
What do you have?
I will also note, the date code and part number stamping on the early blades are on the front, difficult to see when installed in a car with fan shroud.  The later blades are stamped on the back and can be easily seen.  See attached images.
GT350Lad
I'll Have a look today and let you know Corey
Cheers
6S373
6S1276
Rickmustang
Cory are you focusing just on 66 production or a wider look at 64-66 with the early style K code fans?
Just wanted to know where to start and stop and sampling
Hi Cory,
I've also seen G65 plus have in my notes an E65 and F65 being for sale in the past.
Quote from: J_Speegle on March 30, 2025, 06:11:43 PMCory are you focusing just on 66 production or a wider look at 64-66 with the early style K code fans?
Hi Jeff,  I was mostly focusing on the 65-66 GT350 K-codes engines.  But I'm open to any knowledge you want to share.  I know the really early HiPo fan blades are also a little different.
Quote from: s2ms on March 30, 2025, 06:34:14 PMHi Cory,
Hi Dave,  Thanks for the input.  Do you know if all three of your blades were marked in the front?
I've only seen photos of the G65 from an old post on the VMF, no other info on the other two...
OK looked through most of my stuff (low hanging fruit  ::)  and came up with these
Did find one that had a K85 date on it. Not sure of the source
Tried to also include FoMoCo with and without oval around it. Sometimes the FoMoCo are on the same fan blade as the engineering number and date. On others they are on different blades. Didn't include that detail
5E      Hipo Fan Survey
   Fan Date     Stamped   S C3OA-C?
63   L63              Front    No
64   G64              Front    No   No Oval Above
64   J64              Front    No   No Oval Above
64   L64              Front    No
65   A65              Front   No   No Oval Above
65   C65              Front   No   No Oval
65   E65
65   F65              Front   No
65   G65
65   J65              Back   Yes
65   L65              Back   Yes
66   A66              Back   Yes
66   C66              Back           Oval FoMoCo above
66   J66              Back      Yes
67   A67              Front    No     Oval FoMoCo above
67   J67               Back
Hope this helps
