67 Steel Wheel color
Started by Bossbill, September 14, 2018, 01:30:21 PM
Bossbill
On the 67 hubcap cars, is the wheel color semi-gloss black or something a bit shinier?
70 B302   6/6/70  0T02G160xxx
Semi-gloss black sprayed
Original spare tire and rim
Bossbill
Thanks Jeff. I have that pic in my personal library but sheen is hard to detect.
OF course with cleaning and rubbing you can get semi-gloss to have a higher reflective quality and there was likely some small amount of variations in the original painting - daily mix, weather, amount of product applied but as mentioned on untouched originals found most in the mid range of semi- gloss
Bossbill
#4
Thought this might be the best place to post this.
I understand that Ford sourced their valve stems from Dill.
On the hubcap cars these were either 1.25" or 1.5" inches long.
Are there any exterior features of any note?
I assume due to the hubcaps that there might be extenders?
Any features there?
And lastly the cap. Does the cap have a small tit? I thought it did per the pic below.
Bossbill
To add some other data...
Dill sells extenders in these lengths:
Dill
Part# = Length
685P = 0.55"
686P = 0.75"
687P = 1.00"
688P = 1.25"
689P = 1.5"
The valve stems (0.453" hole):
Dill#       Dill ACP#   TR#   Length
T-12-R   T-12-WZ   412   0.88"
T-13-R   T-13-WZ   413   1.25"
T-14-R   T-14-WZ   414   1.50"
T-18-R   T-18-WZ   418   2.00"
T-23-R   T-23-WZ   423   2.50"
These are available in various places like:
http://yourtireshopsupply.com/manufacturer/24/dill-controls?sort=atoz_a&display_pages=0
Now, which one?
You can tell the modern day extenders from the ones used during production. The modern ones have a white plastic ball valve that is easily distinguishable once you know what to look for . The ones used during production had metal silver ball valves that is just as easily to tell that it is different. They were made well into the 70's and maybe later because I pick them up at swap meets from the tool vendors who sell surplus.
Bossbill
Thanks, Bob.
I've heard of people painting the balls with silver, but would prefer metal.
Any idea of valve and extender length on the 67s?
