67 428 2-4 Holleys - Jet Size Primaries?
Started by Mike James, September 29, 2018, 07:14:53 PM
Mike James
Having a problem with my car running too lean.  What jet size should I use in the primaries?
67_1183
Mike James
Thank you.  I'd that what most people are running
Mike James
I meant is that what you are running? Others chime on what jets you are using.
JWH
Here is a link to the Ford Technical Service Bulletin (TSB) published in 1964 concerning the Holley carbs. If you are at sea level, start with #66 jets. I have read for every 2,000 feet of elevation, reduce the jets two sizes, so if you are in Denver for instance, start with 62s.
      Before you take the time to change jets, make certain the floats are set correctly.
http://www.427galaxieregistry.com/1964tsb.html
Jeff
If you made cam changes stock jets aren't going to get it done. You'll likely have to change the secondary plates and power valves with decreased vacuum signal and the rear plates for fuel demand in the upper RPM range, as it will likely lean out.
        -Keith
