1966/67 GT350 Holley
Started by 65fastbackk, January 26, 2018, 02:09:14 PM
65fastbackk
Hi,
I just picked up this 1966/1967 Holley Carb that is missing the choke parts and not sure what else.  Where would I find these, who would you recommend as a good rebuilder.  Does anyone see any another things that are missing or incorrect.
Thx!
try Carl at
www.carlsfordparts.com
He should be able to help you out.
Bigfoot
He is a good guy to call plus someone here might have a few pieces ur missing.
RIP KIWI
RIP KIWI
65fastbackk
Thanks, ill reach out to him.  Do you see anything missing besides the choke plate.  Sorry its my first 715:)
Quote from: 65fastbackk on January 26, 2018, 03:00:36 PM
Looks like the bracket that holds the choke cable to the vacuum secondary pod is missing
65fastbackk
Thank you all! Is this hard to rebuild? Does anyone know a good rebuilder, or should I just buy a kit and follow the instructions:)
67350#1242
Looks like it is missing the threaded plug for off idle vacuum port on the primary metering plate - pass. side.  You may or may not need a plug depending if you have vacuum advance distributor.  If vacuum adv. dist. will need a nipple adapter.
Kurt.
Quote from: 67350#1242 on January 26, 2018, 05:53:15 PM
Kurt.
You need the plug if for 65-67 Shelby. 68 Shelby used a different carb but did have a vac port because the dist on 68-70 Shelby was vac advance . The brass adapter for the fuel filter is needed only if you want the original look. you can use the FG14 like what is on there but it does not look assemblyline. Shelby Parts, Virginia Mustang, NPD sell the brass adapter if you choose the original look.
I had Joe Bunetic restore my carb.   He has been doing it for years.  He also restored the carburetors on the 1st, 2nd, 3rd place GT350s at Pebble Beach in 2015.
If you are wanting it to look correct with redieing, plating and paint markings he will do it.
Find contact information here: http://www.ford6v.com/home/joe-bunetic
