Engine restored for 6S1078
Started by Greg, October 18, 2018, 03:39:16 PM
Greg
I was fortunate that the car had the original engine and had sat for 30 years.  Although it ran okay, I was concerned that it might not have been built properly (the owner said it had been done 30 years prior) so I pulled it and the transmission out (haven't built it yet).  The engine is pretty much done and broken it.  Sweet, sweet sound!!
I also decided the best place for it was inside  ;D (Heat, cool, conversation piece and SAFE!)
Shelby's and Fords from Day 1
BGlover67
Would make one awesome coffee table!
Brian R. Glover
It looks great . How do you feel about constructive comments?
CSX 4133
You sir must either have the most understanding wife to allow that motor in your house, or your single. In either case I'm looking at going through the original motor on my Shelby down the road.
GT350Lad
Yep I do believe that engine is sitting in a carpeted bedroom! Good on you mate, good looking engine right where it needs to be! Although I agree with prev poster, my wife would have my bags packed but my engine is no where near as nice as yours!
Cheers
6S373
6S1276
Greg
Quote from: Bob Gaines on October 18, 2018, 11:52:31 PM
Bob, I have no issues with that as some day the car will probably be judged by you anyway :)
Greg
sfm6s1506
Nice , who did the rebuild for you?
Quote from: Greg on October 19, 2018, 08:16:45 AM
First its great that your open to that.  And to that end
- What color are the side intake, therm & fuel pump gaskets?
- Teflon tape on the rear carb plug - Pic #4
- Need to find an engine ID sticker/decal for over the coil and bracket.
Will leave a few for Bob since I think I know a couple he likes to mention often  :)
Greg
Quote from: J_Speegle on October 19, 2018, 01:38:23 PM
Thank you....
The gaskets
-Intake is dark gray
-Thermostat and Fuel pump are black
-Agreed on the tape
-I will find a sticker
Brant
Here is the proper location of the PCV hose fitting. Hose should then be shorter.
-Brant
Greg
Quote from: Brant on October 19, 2018, 03:52:58 PM
Thanks Brant, I assume the PCV hose is incorrect as well.  Do you have a picture/part number of the correct one?
Quote from: Greg on October 19, 2018, 03:55:49 PM
These guys have all of the things I had issues with . The main visable thing was the PCV in my eye. You can use the pcv hose you have . You take the pcv hose and cut it square where it starts to bend and jam it into the nipple of the fitting . You might want to remove the paper ring on the pcv valve. That was more for service parts instead of assemblyline valves.On the carb you have the wrong filter . It should be the courser thread and it fits into the brass adapter. Also the slotted vacuum plug on the metering block should be silver.
You should get one of the 65 hipo primary wires from Brant that goes to the distributor to the coil. The correct one is a eyelet with black insulation instead of the right angle push on green service replacement.
Quote from: Greg on October 19, 2018, 03:52:10 PM
Thank you....
The gaskets
-Agreed on the tape
The fuel pump gasket should be white from the factory.
Thank you....
The gaskets
All three were originally off white originally. More on one side (one with the spray on adhesive) than the other
Don't have a thermostate gasket handly
Check the engine ID code and get one that matches how your car is equipped
