00212 IN DETAIL
Started by gt350shelb, January 20, 2018, 08:09:49 AM
notice the right side hardware on cowl is one type and the left side attaching  is different
This is  a section of the original floor from around seat belt mountings / the Pink color is what the  entire floor looked like  the darker  red is a later paint job and not factory.
 This is  not original to the car but  looks to be  an NOS rear valance that is  galvanized/  there has been some debate over these ...... in a past forum .  I have seen front and rear  nj built mustangs with galvanized  panels .
Here is the door tag info that was  missing / door tag had been lost prior to my ownership  .........but a previous owner wrote the info inside the shop manual that came with  the car.
I have not tried this  flasher to see if it  helps sequential lights  but it is nos
original oil pressure sender  with nut  on top unlike later ones with post for  wire terminal
reason #1 why you could not get a/c and 3.89 gears
how can you tell  this is early build rad clamp?
location of the buck tag screw
