Mico Master Cylinder-Painted or unpainted?
Started by OldGuy, November 09, 2018, 04:07:45 PM
OldGuy
Guys, I'm in the beginning stages of rebuilding the original MICO master cylinder from my GT-350H (6S803). My primary question is whether or not the casting was bare or painted black? My original casting IS painted black as are many of the internet-posted pictures of this type of master cylinder. I know that this question has been asked/debated before (probably on Forum I?) and folks have posted that their master cylinder casting was "bare". I've noticed also that the steel brake lines are also painted black in some of the photos (I replaced my original lines many years ago and don't remember if they were painted or not). Would either finish be deemed correct? If there are others that have the painted casting, can we get some statistical data?
Any/all shared wisdom would be appreciated.
Thanks in advance for your help.
Frank
Quote from: OldGuy on November 09, 2018, 04:07:45 PM
Frank
Typically unpainted body and unpainted lines is my point of view.
deathsled
I still have mine but it needs a rebuild. May I inquire where you are taking yours to have done or are you doing it yourself? I believe Mico still exists and offers rebuild kits.
Best,
Richard E.
Engine revving to disturb
Body natural cast.  Mounting bracket sg black. Large nut anodized
Yes kit still available but special order takes 12-16 weeks.
OldGuy
I am PLANNING on rebuilding my MICO myself. It is not apart yet so I can't tell if the piston bores will need to be sleeved (I've got my fingers crossed). White Post Restorations is one of the companies that will "sleeve" a MICO master cylinder (in brass). I bought my kit from MICO about 4 years ago through one of their local dealers (they will refer you to a near-by dealer if you need any parts). Contact MICO directly to get your necessary parts/kit and THEN tell the dealer what to order. The dealers will only muddy the water if they are in the specifying loop and you might not get what you need on the first go around.
It's now time to bite the bullet.
I hope this helps.
Frank
Rocket
The original on 6S550 is unpainted. A clutch exploision sent pieces of the pressure plate thru the master cylinder, so had to be replaced. For some reason I have kept the destroyed one since 1983. Ron
deathsled
Thank you for your input gentlemen.  I need to light a fire under myself and get mine rebuilt.  I have a Conra Automotive 1 inch bore dual master cylinder in 843 at the moment.  Original MICO sleeps peacefully with her original engine in my closet.
Quote from: OldGuy on November 10, 2018, 12:43:01 PM
I hope this helps.
Frank
Frank the game has changed. Mico or their dealers no longer keep parts in stock. They are made (in Mexico) on a special order basis.  Had to wait 14 weeks for last one I did
OldGuy
Quote from: TLea on November 10, 2018, 05:30:10 PM
I hope this helps.
Frank
TLea, that's bad news! My guess is that the next step will be total obsolescence. That's why I bought my kit when I did even though I wasn't ready to work on my MICO at that time. deathsled (and others), you may want to order (take a number and wait) a rebuild kit and put it in your closet with the master cylinder. Even if you don't rebuild your master cylinder yourself, whomever does rebuild it will need a "kit" to do the job.
Frank
