ePay intake and carbs correct?
Started by cboss70, November 13, 2018, 01:39:16 PM
cboss70
Can anyone tell me if ePay item number 263905687390 is an original intake and carb set up for  67 GT500?  It may even be a fellow members here but I figured I would ask for people wiser than me to point out what's correct or not. My set-up is kind of a mess and figured maybe I would buy a nice original set-up if the price was right. This is for a driver not a how car but it would be nice to be close to correct  :)
Quote from: cboss70 on November 13, 2018, 01:39:16 PM
What is there looks factory correct as you requested confirmation for with the exception of a few odd plugs ,fuel hose and a few screw clamps. I can't tell if fuel log is genuine or not given the pictures . The main thing that stands out is that one of the carb tags is missing and so is the automatic choke for the front carb. Seller is a forum member although we do not hear enough from him . ;)
Hi Cboss70,
According to Mustangtek, they are correct for a 67GT500.
C3AE-9510-BJ, Holley list 2804, 427 holley 4160 carb Shelby carb, 63 1/2 - 65 427 Ford/Mercury and 67 428 Shelby GT-500
Sec. carb (mounts rear) for 2 x 4V  setup, No Choke butterfly, 600cfm, matching carb C3AF-9510-BK, Metering 4033
C3AE-9510-BK, Holley list 2805, 427 holley 4160 carbShelby carb, 63 1/2 - 65 427 Ford/Mercury, 67 428 Shelby GT-500
Primary carb (mounts front), for 2 x 4V  setup, w/Choke butterfly, 600cfm, matching carb C3AF-9510-BJ, Metering 4033
Eritor
What date is 6o4 at that carbs,early GT500? I have 2 carbs in my garage that have date code 991 for C3AF-9510BK List2804. Did Holley made it for another cars or was it normal stock items? Erik
Shelby GT500 #0329 Wimbledon, black interior, C6.
Shelby GT500 -13 Black with black stripes, TP, PP, Recaro, Glass roof.
Mustang GT 5.0 -17 Magnetic metallic, Ebony Black, GT Performance Package,  automatic transmission, Brembo.
Quote from: Eritor on November 14, 2018, 03:10:03 PM
991 date on a BK carb would indicate a later made service replacement.They were listed in Fords Perfomance catalogs like the Muscle parts catalog.There are many other examples of early Shelby carbs with later dates that verify they were on the Ford parts shelves for replacement use.
KR Convertible
604 should be 4th week of October 66
Eritor
Holley carbs date code 6O4 or 604? Sometimes date code 991 on Holley BJ, BK carbs? Letters and numbers?
Quote from: Eritor on November 14, 2018, 03:31:54 PM
Please reread post #4 . In this case 6 zero 4. There are many other examples of other carburetors earlier then ones used on 67 Shelby with dates like 991 (1st week of Sept 1969) which simply indicated a later produced service replacement carb. Yes sometimes letters where used in the code
KR Convertible
The second digit is the month. 1-9 for Jan-Sep, 0 is Oct, A is Nov and B is Dec. from what I remember.
Dan Case
#9
From one of my old posts......
Holley® Carburetor Date Codes
Part I  O.E.M. Carburetor Date Codes
O.E.M. models, O.E.M. assembly line models, utilize a three digit date code; numbers or numbers and letters are stamped just below the Holley "List" number on the front face of the choke housing air horn. (Service assemblies set aside during production for making cars will have dates in the production time frame.)
Example:      List - 3259
                    4 B 5
The first digit signifies the year the carburetor was manufactured, 1964 in this example.
The second digit represents the calendar month of production, in our example December. The table below details the complete set of twelve month codes.
   Month Codes (Center Digit Of Date Code) for O.E.M. Carburetors
                           Month            Code
                           Jan. ------------- 1
                           Feb. ------------- 2
                           Mar. ------------- 3
                           Apr. -------------  4
                           May  ------------- 5
                           Jun  -------------  6
                           Jul  -------------   7
                           Aug  ------------- 8
                           Sep  ------------- 9
                           Oct  -------------  0
                           Nov  ------------- A
                           Dec  ------------- B
The third digit designates the week of the month produced, the example above was made during week five.
Therefore the List - 3259 above, for a 1965 MUSTANG GT350 289 c.i.d. engines, was manufactured during the fifth week of December 1964.
   II Service Replacement Carburetor Date Codes
Service replacement carburetors, those available over the counter years later at O.E.M. dealers, speed shops, auto parts stores, etc, utilize a four digit date code; numbers only appear in this case, stamped in the same location as before under the "List" number. The service unit codes are expresses as "Julian" dates with the model year of manufacture indicated by the additional and last of the string fourth digit. The Julian date codes table for service models is given below.
   Month Codes (First Three Digits) for Service Replacement
   Carburetors
             Month          Julian Date          Leap Years *
              Jan. ---------- 001 - 031 ---------- 001 - 031
               Feb. ---------- 032 - 059 ---------- 032 - 060
              Mar. ---------- 060 - 090 ---------- 061 - 091
              Apr. ---------- 091 - 120 ---------- 092 - 121
              May  ---------- 121 - 151 ---------- 122 - 152
              June ---------- 152 - 181 ---------- 153 - 182
              July ---------- 182 - 212 ---------- 183 - 213
              Aug. ---------- 213 - 243 ---------- 214 - 244
              Sept.---------- 244 - 273 ---------- 245 - 274
              Oct. ---------- 274 - 304 ---------- 275 - 305
              Nov. ---------- 305 - 334 ---------- 306 - 335
              Dec. ---------- 335 - 365 ---------- 336 - 366
         * Leap Years: 1964, 1968, 1972, 1976, 1980, etc.
As an example of a service replacement carburetor lets examine a current Ford Motorsports Boss 429 replacement unit.
   List - 4647
             2916
This carburetor is definitely a service model since it has a four digit date code. The fourth digit signifies 1986 (It was purchased from Ford in early 1988.). The Julian date indicates that it was manufactured during October. Even though this carb "looks" original on the BOSS 429 engine it occupies, it can not be "original" for a 1969 model car when it was not manufactured until October 1986.
The List-2804 and List-2805 assemblies have wide possibilities for dates as they were a) used on several types of new cars, b) used for more than one model year, and c) used in racing also.
These two models were introduced as a running change during the 1963 model year run of 427 Galaxie 8V engines and were used through the 1967 model year. They were standard equipment on:
- part of the 1963 model year for Ford Galaxies with  427 8V engines
- 1964 model year Galaxie 427 8V engines
- 1965 model year Galaxie 427 8V engines
- 1966 model year CSX31xx 427 Cobras with 8V engines
- 1967 race season Group II 289 race engines in Shelby American Group II Mustang racers
- 1967 model year GT500s with 428 8V engines
There were lots of them installed on new engines over several years. They also seemed to be a popular over the counter offering at least through 1970. The only trick seems to be finding great cores of a particular date time frame with their original dated assembly tags intact.
Dan Case
corbins
Good info there Dan... you smart guy  ;D
cboss70
I have two BK's with the same part number as above ones but the code is 873 on both - so maybe 3rd week of July 1968 so maybe replacement carbs for something?
Quote from: cboss70 on November 15, 2018, 08:37:03 AM
It is more then a "maybe" that the carbs are replacements. I can't think of another explanation given the dates.
JWH
Dan, thanks for taking the time to put together a great explanation and examples of Holley date codes. Would you start a new thread titled "Holley Date Codes," and copy the information again? This would make it easier for those doing searches in the future to find your information. I KNOW I will be looking for it again at some point.
Jeff
Dan Case
#14
Quote from: JWH on November 15, 2018, 07:20:40 PM
Jeff
Hi Jeff,
You are welcome. I didn't see an accessible forum category for general technical details. There is read only library heading but I didn't see anything in it and it is read only.
As a word of caution just knowing basically how things were done isn't enough to guard against all the ways all but the most cautious can be misled.  What do I mean? It is possible to get almost anything rare and desirable recreated in some manner.
Dan
Dan Case
