Engine compartment wiring harness clips placement
Started by Terry Curry, November 14, 2018, 07:15:54 PM
Terry Curry
I'm ready to install the clips in the engine bay that holds the wiring and after reviewing the Electrical assembly line booklet I was hoping to see pictures or a better diagram on how the wiring was routed and what clips were used where. The PO had drilled about 200 holes in the engine compartment (putting metal wire clamps every 4 inches)  and in the process of changing the engine compartment back to black, (It seems every car I have I have to change the color back to stock, Mustang to black, Tiger from black to body color...ugh) I welded up most or all the holes and looking at other cars and taking pictures  at SAAC at Sears Point this past year I still wasn't sure. I have a running early 1967 6 cylinder mustang available to reference but I know there are differences, especially with the center hi-beam headlights and the Tach wiring. Any help would be most appreciated.
Thank you in advanced
Terry
Shelby Mustang GT 500 #504
Is the book you are referencing the Osbourne (sp) electrical book?  (black cover for '67's)
Did you buy the AMK under hood/engine kit?
If I remember it was not too tough, but...
Here are some images that might help, for a start.
Note on the second image since you have a GT500 there is no choke cable - but the Shelby under dash and other items are the same.
Third image note the type of clip use here and the routing.
The straps that hold the loom along the left side have the two eyelet holes, one end of the nub goes in a hole to the body - see last image.
Quote from: Terry Curry on November 14, 2018, 07:15:54 PM
Terry
They early 67 6cyl will have the same holes for clips as your Shelby. That should help you determine which are factory and which were done by the previous owner . That reference along with the pictures JD posted should help a lot.
SFM5S159
I own car #00503, but I don't have info that will help here.  I do have original Shelby paperwork for about 100 cars from #00500 to 00600 that I found under the carpet in my car.  I think I was told somewhere along the line they threw the paperwork in every 100 cars or so?  I will dig it out and post some pics.  Pretty neat find.
Mike C
'65 GT350, '67 GT500, '65 289 Cobra
gt350cs
Would be great to see, as I am within that range.
Terry Curry
Perfect. This helps a lot and yes it is the Osbourne Black Electrical book I have.
Again, thank you.
