1967/68 Mustang engine bay, undercarriage etc. Paint that was used in factorys?
Started by Kent, November 16, 2018, 05:16:24 AM
Quote from: Kent on November 21, 2018, 05:50:07 PM
.......... What paint are you guys using for your restorations to get it concours?
Last couple of jobs I've used Hot Rod black.  It's a little softer than some other choices. Single stage with a hardener but touches up very well if need be
Pretty restrictive here locally for what we can legally buy and apply
Kent
I think this paint thing will drive me crazy so was it now acrylic enamel or alkyd enamel? Becuase there are both answers here in the thread and we know there is a difference between acryl and alkyd.
mustmore
Jeff, in reply #15 you state Hot Rod black.  Which manufacturer are you referring to?
corbins
Kent
was the original undercarriage and engine bay paint now acrylic enamel or alkyd enamel
Quote from: Kent on November 24, 2018, 05:09:35 AM
Undercarriage paint/primer was an epoxy primer sealer/paint according to Ford documents.reference.
Quote from: corbins on November 23, 2018, 07:35:04 PM
Jeff, would this (SEM) be appropriate for the hood blackout ?
Are you referring to the base black used on hoods that were painted body color on the top side and edges?  If so I can see using it for that purpose though I would not use it for both engine compartment and bottom of the hood on the same car out of the can
Kent
Quote from: J_Speegle on November 25, 2018, 10:34:04 PM
So the undercarriage paint was different to the engine bay paint? What did they used for the engine bay? When they had the bare body what were the steps they did to paint it? And which type of colour did they used? Thanks Kent
See reply #1
I think its pretty straight forward. While every plant was not the same, the paint order was the same.
Primer, body color, blackout
If you are not getting the answers you need on the forum, try connecting with someone in your area that has done it before.
Undercarrige paint is primer
Body color was single stage (one component)  enamel
You are asking about the chemical composition of the original paint. I dont think it matters what you use. Most concours cars do not use original paint systems, because of enviromental laws or the fact many of these paints are no longer manufactured. I would be surprised if you can buy single stage, acrylic enamel in Germany. I am pretty sure the original paint has lead in it and it is no longer available.
I think you are worrying too much about the exact type of paint. Pick a paint that you can have sprayed that looks good to you. No one is going to do a chemical analysis of your paint job.
This is like tryingto buy a light bulb. If you go the store and ask for a light bulb for your lamp, they are going to hand you one of theose squiggly things. It will still work.
I sprayed my car with original acrylic enamel and no one even knew. They all assumed it was a base coat, clear coat modern paint.
Even using original materials, replicating the assembly process of baking/curing the paint will not necessarily yield an exact replication.  A good catalyzed paint system that you're (or your body/paint shop) familiar with is best and then mix accordingly to replicate finishes.
Agreed, its kind of like asking what oil was in the car originally.
You can use the same oil, but there are a lot of other choices and one could arugue, better choices. Things have changed and its about working with what is available.
Agreed it's about the final results and that is the fun/challenge for restorers. How ever you achieve the end goal (looking like an original finish) it up to you and if involved your painter.
Be careful if you choose a straight primer for a finished surface sine these are often porous (on purpose) and can rust through. Primer sealers as they were referred to as seal the surface
corbins
Quote from: J_Speegle on November 25, 2018, 10:34:53 PM
http://www.tcpglobal.com/SEM-HR010_5.html?utm_source=msn&utm_medium=cpc&utm_campaign=(roi)+product+listing+ads+-+tcp&utm_content=all+products&utm_term=automotive+paint&msclkid=8ef00444ca521c5431de5fbc4df0aa25
I was referring to a 69 hood blackout treatment. Would this SEM product be appropriate to the blackout ?
Thanks !
