Center headlight bracket style
Started by Bob Gaines, November 21, 2018, 01:56:10 PM
Who has the three hole and who has the two hole don't forget your Shelby VIN and Shelby completion date if known. Thanks.
Alan
Will check when we return fm SPI.
Max
'67    0029
Richstang
#0345 GT500 SJ completion 12/27/66 -SA completion 1/06/67 - extra hole on right side of car (Slanted grille)
Photo from "Dragon Wheels Restorations"
1967 Shelby Research Group
www.1967ShelbyResearch.com
67_1183
Note:
The first image the piece in question is one piece for both light buckets to attach to and has the 3 holes as well as the buckets are attached to the plate with self-tapping sheet metal screws and the wires have the sheathing.
The second image is two separate pieces each with one hole and the headlight buckets are attached to the plates with bolts and the wires are tape wrapped.
(Both of these seem to be posted up-side down, below they are rotated to match the image in the second post showing more of the car.  Also the second post with the green car shows a two-piece nose)
greekz
#2339 has a 3-hole mounting, SA completion 5/23/67.
SFM 6S1134  '67 GT-350 #2339
Bossbill
01375; two hole; SAI Build Date 4/15/67
70 B302   6/6/70  0T02G160xxx
#875 completed 4/6/'67 shipped 4/13/'67
2-hole version just like the 2-hole version pictured above.
KShane
#2213; 2 hole version, complete 5/12/67
67350#1242
#1242 - 2 hole style.   SA completion 3/15/67.
Shelby_r_b
It's funny - I didn't even think as to whether or not early cars had this backing plate.  I went to look at #22 and didn't seen anything like what was pictures.  And, then I remembered...  ;D
Nothing beats a classic!
67gt500
#11
#486 - 3 hole - SA completion 1/31/67
BGlover67
Quote from: Shelby_0022 on November 27, 2018, 10:52:44 AM
Ruben had an 'early brain fart'.  :)
But seriously, for anyone that has never seen the early configuration outside of a car, it will surprise you.  It really illustrates the hand made aspect of early 1967's.  I restored the original set off of no. 83, I was really amused how non-symmetrical they actually were.  The bushing on one side was 0.25 inches larger than the other side. Like a good friend once said to me, it looks like a drunk cubscout was making these cars back at LAX.  :o
Brian R. Glover
owenkelley
#589 has the three hole design, but it looks almost like the bracket is kind of a combination of the two shown above. It does not have the bracket that goes all the way from one side to the other, the bracket looks more like the one on the two hole design. Don't know how common that is.....Shelby completion date - 01-11-67
rbarkley
#861 - 2 hole style.  SA completion 3/15/1967
