Source for upper scoop lights?
Started by mwilson7, December 16, 2018, 07:37:11 AM
mwilson7
Could someone direct me to a source for replacement lenses for the upper scoop lights?
TIA!
Mark
Lots of Fords
What car # do you have?  (Is this an early completion date car that you have or is this a Owner added or tribute??)
Have you seen this thread regarding these lights?
http://www.saacforum.com/index.php?topic=433.0
Which lens(es) are you trying to replace?
If the correct originals those can be a bit pricey.  If you just want one/some of one of the other later versions those are not much - dollars wise and I know some one that has some of those.
BGlover67
Quote from: JD on December 16, 2018, 09:51:56 AM
+1 Yes Mr. Wilson, you have our attention.  :)
Brian R. Glover
Mark, looks like you need the bulb(s) and a set of lenses.
Suggest getting a set of the later lenses they fit and do the job for starters. You might want a fresh set of lens gaskets too, those old ones might be failing.
PM me, I or some others can help.
mwilson7
Thanks for the responses!
JD - I'll reach out to you in a week or so when I know exactly what I need.
Mark
Lots of Fords
