BJ BK carb question
Started by BeaterGT500, December 18, 2018, 05:24:57 PM
Quote from: 2112 on December 19, 2018, 10:43:22 PM
I am curious, how long does that once finish last?
If you mean the finish on a restored carburetor last then it depends on environment and fuel you use and if the fuel gets on the finish. The zinc silver and gold chromate finish's will deteriorate at different speeds. A couple years out in the real world being used and it starts to go away. The gold first and then the silver.
owenkelley
I have the original BK carb for my car, but the PO had removed the dual four barrels and ran a single four intake with the one original carb. The BJ carb and intake was stolen from her garage, so when I bought the car that's all I got. I rounded up the correct intake and found a BJ carb, but it is too early of a date code. I asked a prominent Shelby enthusiast how important the correct date code was on the carb, and he told me he would just have it re-stamped with the proper date code. I chose not to do that......
Quote from: owenkelley on December 20, 2018, 05:06:02 PM
I am not sure how a already stamped date into the air horn of a carb could be re stamped successfully anyway. Carl's Ford will stamp on request the reissue carbs he sells however on those they are blank in that typical date area to begin with so it is not a issue.
hertzdonut
Just spoke with Joe. Very easy to talk to.
Terry
tonys_shelby
For added info I sent my Carbs in to Holley for factory restoration and it was about the same money your talking about and I think the pictures of the ones Joe has done are better and I'm thinking I will have him do it right.
