Under Dash Wires?
Started by DennyD, December 22, 2018, 06:27:54 PM
Factory A/C was a yellow fused jumper wire off the back of the ignition switch and a black compressor switch lead from the under-dash unit.
I dont think so, ac was not a built in option until 1967.
...did you check with power on and headlight switch on?
DennyD
No, I only checked with power on didn't think to pull the headlight switch at the same time. Good catch, I'll check that too.
