frost plug
Started by johnzajc@gmail.com, December 23, 2018, 03:08:16 AM
johnzajc@gmail.com
Hi---need set of 428 cobra jet frost plugs--thank you
They are a standard 1 49/64 Doorman plug. I have an entire engine galley plug set. Core plugs are brass.
        -Keith
Quote from: 1967 eight barrel on January 02, 2019, 09:20:18 PM
        -Keith
Assemblyline plugs will often have a diamond makers mark. Sometimes the makers mark is visible on the side that can be seen  from the outside and sometimes it will not be visible because the mark is stamped on the inside surface of the plug. If no diamond makers mark visible then the plug better be plain with no size markings or other trademarks visible. Many times the block is not painted well from the factory on the sides and the silver color of the plugs can be seen.
Dizzy
Ford # C8AZ 6026 A  by my book measures 1.76 like these
The correct core plug size is 1 49/64.
Are those steel or brass plugs?
                                          -Keith
Quote from: 1967 eight barrel on January 04, 2019, 02:51:00 AM
                                          -Keith
Factory ones are steel . Brass ones are not but will not rust through like the factory ones. The OP has been trying to find a lot of factory type parts for a restoration.
It appears they are overseas. I was trying to offer options.
                                                         -Keith.
mistabreez
I believe the updated Ford part number for these plugs is D7AZ-6026-B (10 per box). Years ago I bought two boxes to get a set with diamond logos all showing on the fronts.
C.J.
johnzajc@gmail.com
Hi--does anyone has them for sale---thank you
Dizzy
How many do you need? I only have the ones shown in my post near the beginning of this topic. Some have the marking facing out,others in. These are the C8AZ pieces and are correct for your application. Just let me know.
johnzajc@gmail.com
Thanks ---I would like to do entire car , plus some spare, how many would you sale, I believe there is 10 in the box-
Dizzy
johnzajc@gmail.com
Good - thanks done deal---send me payment information
