For a '67 GT 4spd. Coupe
Started by Survivor, February 04, 2019, 12:23:21 PM
Survivor
Looking for the following nos or good used condition:
* trunk mat & fiber board
* radiator cap
* low fuel sending unit (convenience control panel car)
* antenna
* aqua carpet set
* shifter boot
* air filter for smog system
* intermediate muffler
* vacuum advance unit
* door bumpers
Quote from: Survivor on February 04, 2019, 12:23:21 PM
Are you looking for the metal canister/air filter housing or the foam filter inside that unit?
Dizzy
I can help with vacuum advance. Please let me know more info....complete or diaphragm ?
BGlover67
Brian R. Glover
Survivor
Also looking for a fan shroud w/ rectangular logo which I believe would be correct for a very early SJ built car and a battery tray.  Thx.
Quote from: Survivor on February 05, 2019, 09:00:45 PM
Just in case you were not aware, the battery tray is also 67 specific with pre drilled holes for vacuum canister mounting which changed late in production.
stangman39
WCC has a low fuel sender on their site but out of stock.  Not sure if or when they are getting more.
A 67 GTA 390 FB I had still had the factory one in the tank.  I was surprised to see that.
Bigblock
Quote from: stangman39 on February 06, 2019, 08:56:45 AM
Most vendors that had those don't anymore due to wrong resistance on the slider. Your gauge won't read correct.
The manufacturer so far hasn't made a correction.
West Coast Cougar and NPD offer a conversion that is solid state that plugs into the factory relay and only requires pushing one terminal out of the relay block and running two leads to the fuel gauge. I put one in my Shelby and it works better than the Ford unit.  It comes with a solid state board that plugs into the relay block, a solid state dash voltage regulator and the two leads that go to the fuel gauge and back to the terminal block. The impossible to find sending unit becomes irrelevent.
        -Keith
https://secure.cougarpartscatalog.com/elfi78.html?attribs=75
