oval air cleaner mounting backet
Started by JessC, February 14, 2019, 04:45:33 PM
JessC
Hi,
I have a oval air filter Assy.  with studs at both ends coming thru lid. I need the bracket to hold this on the carburetor.
What do I do?
Jess
Tired Sheep
There is no such bracket. If your oval cleaner has two studs, it will either have a hole in the center or a mounting bracket in the base
JessC
If the base is metal, it is either mismatched to the lid or the welded bracket has been removed
Quote from: JessC on February 14, 2019, 04:45:33 PM
Hi,
What do I do?
Jess
That hold down bracket is what the repro air cleaner people use. It was not used on genuine air cleaner assemblies.
